Just put this shackle on
fourdayoff
Boulder City Nv
2022 Bronco Badlands/sasquatch 2.7
To the original OP. This factory hitch is rated for 350lbs tongue weight and 3500lbs trailer weight. I would not use your setup for anything much for recovery. If you think it looks cool then DWMYH. Jim. P.S. Crawl under the back and take a look, you'll see. I'm surprised it's rated as high as it is.
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
If the concern is recovery points mounted to a lateral frame member, does also make the recovery points welded to aftermarket rear bumpers also suspect? My understanding is that the bumpers themselves are bolted to lateral frame members as opposed to longitudinal frame members.
Also, if the OEM rear recovery points should only be used once, how do you go about beefing up the recovery points so that they can be dependable? Is there a particular product that is recommended? Thanks.
IMO, I'm not trusting a Tulsa Welding School graduate who's first job is to churn out bumpers with welded recovery points on the surface of the bumper. I've seen them fail and have seen fancy bumpers torn off. Now, those suppliers that do opt for that design need to show the reinforcement behind those points and how they are tied back to the frame. Otherwise, tits on a bull...
Now, if you want to see a proper recovery point incorporated in the bumper, look at SRQ's Dual Swing-Out Carrier bumper. Ignore the fancy carriers and just look at the recovery points that are mounted directly to the longitudinal rail and pass through the bumper. They are a thing of beauty.
With regards to recovery techniques, there are hand-on courses that you can attend. If you have a local group, then set aside some of the planned wheeling time for actual practicing recovery techniques. Create scenarios, form an action plan, hold after-action reviews, and everyone benefits.
murphtron
T
Berkeley, CA
2023 Badlands, 2013 Toyota Highlander, 2000 Miata
There are a couple of threads on here about bent front frame horns. Search for @Tricky Dick’s experience. He also has frame horn reinforcement brackets available from his shop. I’ve got them. Lobo Off-road also has frame horn reinforcements.
Good discussion on risks of using a tow hitch for recovery, especially from sticky mud. Think I’ll stick with using the OEM recovery loops with a tree saver to triangulate.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Yeah, I think @Tricky Mike had the same issue too. Such a coincidence!
Toccoa
Isuzu Rodeo Sport
Canyon Coolers
Jason
Flagstaff
canyoncoolers.com
73 Bronco, Dodge 2500, Sprinter Van
Monster Hook, a sponsor here, makes a solid metal replacement for the OE recovery point on the rear of the Bronco. I just got some, need to bolt them up. They are for designed for soft shackle and bolt directly to the longitudinal frame area.
Ford Bronco Just put this shackle on 1696876143635
Pilsner
JTR, 81 Bronco, 21 BD
The tow hitch on any vehicle is designed for towing and attaches to a lateral frame member. The forces incurred in towing is different than that of a snatch to overcome a vehicle stuck (mud having the greatest suction force to overcome). You want the force used in such a recovery to be applied to a recovery point that is a part of the longitudinal frame member.
It was just a week ago that a recovery went wrong at the Ol' Florida offroad park. Landcruiser was stuck and recovery was attempted from the tow hitch. In a split second, the entire hitch carrier was torn off the LC and sling-shot into the rear gate of the recovery vehicle. People standing around in the kill zone unknowing the danger that they exposed themselves and their loved one too. In that split second, the carrier could have easily killed them.
The hitch is as reinforced as the front recovery hooks. Hell, most aftermarket bumpers attach the the same points that secure the actual hitch. I have not had this bumper off, but the Tacoma uses the same 4 bolts for the hitch and aftermarket bumpers. The factory bumper only secures to the hitch itself. The pic above wasn't a hitch failure, it was a mounting point failure and I'd be interested to see that up close. There is always danger in recovery. I have no issues using a good hitch mount recovery point.
HoosierDaddy
__ Eric
NW. Indiana
https://l2sfbc.com/drop-hitch-failure-leads-to-death-during-4x4-recovery/
Some good reading. ^^^^
This is the hitch type failure that most are reffering to, as well as the incidents where the ball shears off and gets sling shotted into somebody's face at 200mph.
Also, cross tying the frame recovery points using a tree saver can cause them to bend in towards each other.
If I were to do that, I'd want two identical straps as long as reasonably possible to decrease the angle, otherwise using one and trying to get straight on with it is obviously the best scenario.
If you are applying so much force you are concerned with pulling a ladder style frame out of square, you probably need to stop and reassess the situation and probably re-rig.
Ford Bronco Just put this shackle on 1696906251277
Ford Bronco Just put this shackle on 1696906291655
Ford Bronco Just put this shackle on 1696906319295
Ford Bronco Just put this shackle on 1696906345808
RowsKing
JR
SJ
22 BRaptor, 66 Stang
Fords 2 piece recovery point isn’t even completely welded. Just on the side you can see. Not sure how much you should trust that.
Ford Bronco Just put this shackle on IMG_0218
Ford Bronco Just put this shackle on IMG_0217
fourdayoff
Boulder City Nv
JR, thank you for the pics. I will be welding the backside. Jim.
swooshdave
Portland, Oregon
Mustang
I'm guessing that Ford doesn't publish the weight ratings on any of the recovery points?
swooshdave
Portland, Oregon
Mustang
I was not the best example for a lot of the new people with me, as I did not have a damper on the line, and at one point I placed myself in the danger zone.
We all can learn a bit more.
Isn't a line damper preferred but not required for a synthetic line?
RowsKing
JR
SJ
There is no rating on the factory recovery loops.
RowsKing
JR
SJ
I went with Monster Hooks Inc soft shackle loops.
Quality solid one piece product.
Ford Bronco Just put this shackle on IMG_1452
Ford Bronco Just put this shackle on IMG_1450
broadicustomworks
Hanging Rock, North Carolina
Not required but a few reasons why I should have:
1) Most of that group were very green. If I'm being watched and people taking notes on how to do things, as a responsible "teacher" I should show them the right way. If they don't see a damper used and ask "what is that for?" They may not even know about them or when needed...If one of that group gets a steel cabled winch and is unaware of what a damper does... Boils down to being a good role model. Show people the correct way if you are in that position of others watching what you do and how you do it.
2) granted a synthetic line should/would just snap and fall to the ground if the failure is the line itself between the two vehicles/tree/etc. However, if the failure is the shackle or recovery point at the end, technically it could still whip back and basically be a projectile due to the energy/force.
Probably best case to be more safe than sorry. And regardless, I should not have been so caught up in getting it done I was not a good teacher to those watching me.
It didn't even dawn on me until I watched the videos and pics of the recovery back at home.
