Do I need hard shackles with this set-up?
U725Bronco
U725Bronco
NorCal
Serious question....in what scenario would a hard shackle mounted to this front recovery hole be preferred over a soft shackled mounted in the lower spot or is the hole only there for folks that only have a hard shackle? Basically trying to decide if I should also buy some hard shackles or if I'm good to go in any kinetic rope recovery situation now.
chtucker
Kirkland, WA
FJ Cruiser
Haha....I didn't even think of that lower mounting spot. It looks like you have the same shackles too. Good to know...thanks!
This plus buy soft shackles with a chafe guard. Either canvas or plastic dipped chafe guard.
i Have never had trouble getting them apart after really yanking on them.
they are also super cheap to make at home. There are bunch of YouTube videos out there.
Murph914
Franklin, MA
2008 F-350 reg cab srw v10 manual
you should have hard shackles because you don’t know what the other vehicle has. A receiver mounted shackle is another nice thing to have, certainly not mandatory. Soft shackles will work with a clevis pin in a hitch, but only straight. If they get cut under load on a kinetic rope you’re screwed.
U725Bronco
U725Bronco
NorCal
Ahhh, good point....thanks! Clearly I'm new to this offroading recovery thing ;)
Vantcrst
CA
92 Ford F-150, Mercedes 4x4 Sprinter Van,
Your recovery gear bag will depend on how far in to the weeds you want to go. But like above says it is good to have a couple D shackles for rigging because you don’t always know how or what you are going to find on other vehicles. If you have a couple soft shackles, D rings and a kinetic rope that will get you out of most situations assuming you are traveling with other vehicles.
BroncoKong Jr.
Andrew
It's best to have both because you never know what the situation will be. I have GA Uber shackles on the front bumper (and one on the tow hitch) plus some Gator Jaws.
