Do I NEED a freezer for overlanding?
murphtron
T
Berkeley, CA
2023 Badlands, 2013 Toyota Highlander, 2000 Miata
Having used a friends Dometic on a few trips I must admit i like the convenience of a fridge. Things don’t accidentally get wet like in an ice filled cooler.
But the downsides are that you gotta have a battery - which is more money and takes up space. Yeah I know there are ways I could hide a battery, and I’d likely do that if I was 100% convinced the fridge was perfect for my needs. The amount of ice the Dometic produces is laughable. If you want to mix some martinis at the end of the day, well, you’ll get one round. And that’s the issue. It really depends on what you need. And if you need ice, the Dometic won’t supply much.
Of course I have seen people with dedicated ice makers. More gear… yeah!
I do like the fridge though. I’ll keep borrowing my friends. :)
Seahund
Adam Webber
Carlsbad, CA
Chevy Tahoe
Sweet, I'm officially an overlander, I have a fridge!! LOL
No game meat. I don't see being off the grid more than 3 days before finding a store/fuel. If I have to choose between beer or ice cream...I'll go with nice cold beer!! Gear, yes, I have a list, need more gear!! 😁
Guess my main concern is that if I'm building a nice storage/kitchen system, its essentially built around the fridge. I could add an inch or two of extra space beyond my current fridge specs in case mine fails and can't get or don't want the same one again.
If you precook some of your food and put other fresh items in the fridge you don't need s freezer. If you have kids (ice cream/pops) or need ice for drinks... then you're stuck. I'd stay with the fridge. Good enough for Overlanding IMHO
SeptuagenarianSasquatch
Randall
New England
Consider forsaking some of your First World Amenities as you escape "the world." Something to be said for roughing it. You manage without plumbing out there, don't you?
nwGTS
Nate
Chicago, IL
Porsche 911 GTS, BMW M3, VW Golf
This is the only way to do it:
Ford Bronco Do I NEED a freezer for overlanding? 1707929701051
Durangatan
Marty
Durango, CO
Bronco, A6 Avant, TTRS, SQ5
Negative. I keep ice in a 75qt Yeti for 6 days on river trips. Temps are often either side of 100F.
akturbo
akturbo
Seattle Eastside
'21 Bronco, '24 2D HLE (wife's), 3500HD Chevy, Rav4Prime, Turbo Skidoo
Cracking me up! I opted to stick with the BougeRV. I left it running at 33 degrees after wheeling Saturday, came back Tuesday morning and the Bronco started! Put that $1k for a fridge toward a new suspension, much better than a freezer!
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
IMPO no. Having owned a full on built expo Tacoma in the past I have no plans to add a dual battery system / fridge to my Bronco.
With proper menu planning and a good rotomolded cooler you should be fine for multi day trips. I’ve had several 5+ day trips in the desert with no fridge.
I gave up on regular ice years ago in favor of freezing plastic jugs. While not perfectly dry, the bottles sweat as they melt, it does keep the inside much cleaner. Plus as they melt I just drink the water.
In other news surrounding cooler management: more whiskey, less beer. Problem solved. 🤪
