Interior Fan a/c & Heat
Bronco SWAT
Caroline
2025 Bronco
Hello, Is there a way to totally stop disengage the interior fan?
When my tops are off or windows open, there is no reason
to have the fans / air through the Bronco. In my Ranger,
I could turn the fan off completely.
Many thanks (yes I looked in the Manual )
Deadpool392
New Bern, NC
2025 Marsh Gray Bronco Raptor, 2020 Gator JTR (retired)
Are you wanting to turn the AC/Heat off? You just push in on the temperature adjustment on the driver side and it will turn on/off. You can also turn it back on by turning the fan speed up.
Area51BS
Ron
Badlands non SAS 4dr 2.3
Never paid attention, but is it the annoying Ford timed ventilation refresh kicking in or is it on all the time? If it’s on all the time then it’s broken.
Can’t wait for the 30 degree drives this winter with heat on and Ford kicks in the outside air to make sure I don’t suffocate.
Area51BS
Ron
You could always do this before fan starts and prevent it from moving. Just be careful on where you drill hole.
DALOLA
Retired
Ohio 🇺🇸
'24 Mach-E, '22 Maverick, Hot Rods
Yeah, you have to turn the HVAC off to also turn the fan off. If HVAC is on, the fan will not shut off, it will only go down to level 1.
Bronco SWAT
Bronco SWAT
Caroline
2025 Bronco
Many Thanks for your inputs and info.
I will update here if successful at turning off completely.
I did have HVAC system turned off.
DALOLA
Retired
Ohio 🇺🇸
So, you're saying you had HVAC off, but the fan was running? 😲
Bronco SWAT
Bronco SWAT
Caroline
2025 Bronco
Yes.
An update . I am a bloody idiot. On the front of the temp setting, driver side, there is a power
emblem. Upon pushing that in, the fan turned off.
Thanks So much folks.
not on the rug
2024 Wildtrak. 2011 BMW X5M. 2024 Nissan Pathfinder Platinum
Yes.
At least you weren't too proud to ask for help.
There's no such thing as stupid questions, only stupid people. :crackup:
Bronco SWAT
Bronco SWAT
Caroline
2025 Bronco
Ford Bronco Interior Fan a/c & Heat IMG_0281
helifino16
Ron
Mount Sinai, NY (Long Island)
The ex had a convertible Saab back in the day and it was annoying that when the top was down, the AC could NOT be turned on. It would be refreshing to have a little breeze when you come to a stop. Yeah, I'm the guy running down the road with the windows down, AC on full. lol
Headsong
Yes.
Took me weeks to discover this....drove me crazy, too. So NOT intuitive.
Dan-O
Dan
Fountain Hills, AZ
Yes.
Yeppers….thats how to turn off the climate control system👍🏼👍🏼
Just to rub it in, you know us non-premium HVAC folks can set fan speed to zero.
#BaseTrimSuperior
