Installing a sway Bar Disconnect
robinsto01
Stone
Plant City Florida
Ford Bronco
I have a non-Sasquatch Black Dimond and I was wondering if anyone new of a way to instal a sway bar disconnect and if it had to be manual or if I could wire it to one of the 6 auxiliary switches.
fordbroncowildtrak2023
Phoenix, AZ
Silverado, Bronco
userdude
Denton, TX
2023 2dr Badsquatch
Phoenix, AZ
Silverado, Bronco
I didn't know about the Rock Jock product until recently. It looks appealing.
Another choice is to remove the links and run disconnected all the time.
Dusty
Mentone, CA
70, 71 & '21 Broncos
Consider taking the whole sway bar off for a while and see if you're OK with how it handles. Put it back on after a week if you don't like it. That's what I did, and never put it back on. Flexes better off-road and I don't really miss it on-road.
Fishwrinkle
12 GC overland 5.7, 18 GC srt 6.4
I have these being delivered tomorrow. I pre-ordered about 6 months ago for $150. They look well designed - we'll see...
https://privatelabelmfg.com/product...ford-bronco-2021?_pos=1&_sid=373f46d62&_ss=r#
are the end links in the disconnects right AND left hand thread? curious cuz @acfab only used RH threaded heims. cool, thx for that so now you have to constantly put them on and off to get it set up and fine tuned. it also sucks when the mounts get tweaked and then have to fight them off. my $300 set is permanently disconnected. only thing i can't do is take sharp flat corners fast on the road. not a biggie really.
OP, like dusty said, just disconnect your factory links and drive around. hit an empty lot and do some gradual swerving to see how it effects your driving.
gerby151
Randy
Clayton, NC
'22Bronco Badlands (Honcho) '09 Harley Davidson
If it is like the 97 and 04 jeep I had when the swaybar link broke it would cup the front tires so be aware
Fishwrinkle
i had an alignment done with sway disconnected and they didn't say anything about prior issues, nor did the spec sheet
Arokcrwlr
Kraig
US - Alabama
I'm not sure on the end link threads. I guess I assumed they are LH/RH. I'll find out tomorrow when they are delivered.
Fishwrinkle
let us know, thx. i assumed that with acfab also. it's a fancy turnbuckle so get with the program
