BAUS67
redneck
Central PA
Nice! Is that style more for deep water fording or better cooling due to the location?
Water wont hurt the IC. This is more to get the IC up out of the way so the winch does not block it when mounting the winch between the frame rails.
Keep the IC high and the winch tucked in so you don't kill the approach angle.
I have seen a few Broncs that have smashed the front skid enough that it also smashed the IC when it is mounted down there. Not a big fan of that trans cooler down there either but I'm running out of space to move shit to.
Razorback
Dallas
Lincoln MKX
BAUS67
redneck
Central PA
Is that the Lobo off-road kit or did you fabricate yourself?
DIY. Had the local metal shop bend up some plate then just trimmed it up and drilled some holes in it. The center of the bumper had a tube and mesh in there, so I cut that out and bolted the angled plate in there. Worked out pretty good for the bumper not being designed to have a winch in there.
That bumper has a winch mount similar to Fords setup. Bolted up out in front of the bumper.
Keith J.
Keith J.
2024 Bronco
Makes sense.
Tricky Mike
21 Bronco
Guilty. The high mount is what I'm eventually doing to replace it with. Do the pipes protrude forward any more that the original IC? I only have 1/4" to spare.
BAUS67
redneck
Central PA
That is a good question I never measured it, but I can. I dug through my photos and found these. It looks like it is about the same distance, hard to tell. There is just no brick in the middle anymore, it's in the grille now. I will post some pics with measurements later.
Ford Bronco Installed a Mishimoto Intercooler Today IMG_0485
Looking up. The big round hole to the left is the IC mounting flange. The small hole in the tab to the right is where the stock skid bolts up.
Ford Bronco Installed a Mishimoto Intercooler Today IMG_0533
Tricky Mike
21 Bronco
Sounds like it might work, I'll take a look. Thanks!
l88m22vette
IL
Please sir may I have locking diffs?
Have you noticed any changes in water/operating temps since install?
Keith J.
Keith J.
2024 Bronco
Operating temperatures are the same. Haven’t monitored the intake air temperatures yet but I can tell that the heat soak doesn’t happen. No power lost after idling for longer periods of time. The stock one was very noticeable after longer idling periods.
Canyon Coolers
Jason
Flagstaff
canyoncoolers.com
2002 C5 Corvette, Dodge RAM 2500, Sprinter Van 2500
Much better throttle response, heat soak is no more, and it has much better drivability overall with the Ford Performance tune and the other upgrades. It really complimented all of the upgrades. It's a really fun vehicle to drive now.
I just did the high mount Mishi intercooler. Along with the Ford Tune, charge pipes, CAI and Fast Intentions exhaust this thing is punchier then ever, and it feels like it compliments all the other performance mods.
DangerMTBBronco
Dale
Lake Elsinore, CA
youtube.com
2022 Bronco Badlands Sasquatch
Nice! I’ve got the tune not sure if the intercooler is CA Carb legal. I need to see. You know I need more Baja juice!
Keith J.
Keith J.
2024 Bronco
Yup!
CarGuy
New Jersey
2023 Ford Bronco
Did you have to remove the radiator shutters?
