Hi-Lift jack mounting
Elmer Walker
Elmer
San Diego, CA
Toyota Tacoma
Going to purchase a high lift jack soon. What is the best way to mount jack in the spare tire location and suggestions on best jack for the money? Gracias, Elmer
Aonarch
Jack Hoff
MT
I have a feeling most people here do not recommend a high lift, myself included.
Heavy, dangerous, and are typically for decoration on people's rigs. Seen bolted to a Wrangler hood, rusting itself to death.
I prefer a bottle jack, or the Harbor Freight off-road jack.
V1Rotate
Brevard, NC
2022 Wildtrak
Not to mention no lifting points without something aftermarket..
But “overlanders gotta look overland”.. could probably even find one with a matching shovel to mount next to it and the unused traction boards
Aonarch
Jack Hoff
MT
Lol I just saw a completely decked out Tacoma with all of the overlanding gucci items, complete with the stickers still on them.
That fancy $600 shovel, spotless with the barcode and product detail sticker still on the shovel blade.
Back on topic, yeah we do not have any hi-lift jack points.
My last rig had them built in to the bumpers and sliders.
V1Rotate
Brevard, NC
2022 Wildtrak
Most people’s only halfway legitimate argument for a hi-lift are that they can’t get their vehicle off the ground with anything else. That simply isn’t true you just don’t know how or don’t have the right jack. A good bottle jack will work just fine and I’m substantially lifted and currently run 37’s and off-road a bunch. If you want some peace of mind for that one super low chance occurrence where you can’t possibly move to level ground and the wheel you need off the ground is worst case scenario then carry a short piece of 4x4 or 6x.. not any less safe than a hi-lift in the hands of someone that doesn’t use it often
Aonarch
Jack Hoff
MT
That is exactly what I do. :)
Your best bet for using a hi jack is to loop soft shackles on the recovery points and hook into those. A good rock rail could probably lift your rig in a pinch but unless it's got something you could loop a shackle through I wouldn't use that from the side - too big of a chance of it sliding .
I've only had to use mine a few times, and it is usually involving my tractor going off something too steep. But I've thought about using it to help move deadfall, and it's handy in case you run up on someone else that may have hit something just a bit too steep - just usually get lucky and get other ideas to work before I have to break it out.
As far as mounting the thing: @BigMeatsBronco had a good mount that went up along the roll bar around here somewhere. On the spare tire, I've seen a few kits there - Havoc Offroad and RTR have some that have a plate that goes behind the spare and the hijack mounts horizontally on that., or there are carriers that will bolt to the tailgate hinges (have to watch clearance, especially if you have halogen tail lights). I've seen a couple of front bumper mounts as well that look decent (assuming you don't have a winch in the way).
This isn't a bronco but I love the pink rope
Ford Bronco Hi-Lift jack mounting 1721659843663-5j
Fordified1
Bob
Mid South Texas
I made fun of my friends for having them then needed two (the second one to stabilize the first) to get mine high enough to get the wheel / knuckle assembly out from under my rig on a steep incline. Had to hold my truck with a winch and even then it was sketchy in loose rock.
Hopefully won’t ever need one again, but plan to eventually mount one on a swing away spare type bumper. A bottle jack won’t go high enough to do what we did. They are definitely dangerous, but nothing lifts as high or as quick (I was blocking the trail on Imogene Pass).
Felix808
SRV CA
The best way to mount a Hi-lift outside on the rear is with an aftermarket bumper with swing away tire carrier, but you can probably make a mount to attach it to the spare tire.
Hi-lifts have bailed me out a few times. I carry one inside (keeps all the trail grime & rust off of it) I use it with a lift mate so I can lift at the wheel. I also use it to lower & raise the spare tire when needed as a 37" tire & wheel aren't too light :wink:
It can be a very versatile tool, but one needs to know how to safely operate it & be cautious when doing so.
YMMV 🤠
X-Rack
Nick
Bethpage, NY
2022 Ford Bronco
cynicalrider
First gen taco
Hi-lift is an incredibly useful tool in the right hands. It also can be finicky and usually needs lots of lube to continue to function properly. That being said it's bulky which makes mounting locations on these trucks difficult. If I were to do it I would mount it vertically next to the spare.
Sure a bottle jack could have worked here from the rear diff but then I would be fully under the truck to use it...
Ford Bronco Hi-Lift jack mounting 53692065023_8c50adac75_4k
Untitled by MJH Creations, on Flickr
I am currently exploring another option for the Bronco that is a weld together solution based on a trailer leveling jack called the Tauler Jack from Brennans Garage.
Ford Bronco Hi-Lift jack mounting 53874091189_2fd2d05283_4k
Ford Bronco Hi-Lift jack mounting 53873688334_f8e8143250_4k
And the plan is to mount to the M2M attic shelf.
Ford Bronco Hi-Lift jack mounting 53874083349_7fed03e8a9_4k Untitled
It's greasable, has no hydraulics that can fail, and has no risk of teeth getting bashed out (if you are stupid enough to put your face in the way) when it uncontrollably CLACK CLACK CLACKS down. If you have seen a hi-lift do this you know what I am talking about. :crackup:
CalvinT
Calvin
Phoenix, AZ
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
I can just picture those traction boards jettisoning on the first ledge one drops off :unsure:
@xrack is a very high quality American made product. The MFG is a Bronco owner and an avid fisherman. I own the over the spare Xrack. The tractions boards and everything else is locked and secured...
