Hi all
DrRoboto
Oregon
I always connected my Mac to the car via Bluetooth and I had no problem with that.
You can also try a USB-C cable.
If you want to generate electricity individual speaker curves based on a house curve, I would suggest to use TUN4 software from JL, I use it in demo mode and generate my speaker curves based on my house curve.
There are only few DSPs that have an integration with REW and you can import the EQ filters in. mObridge unfortunately does not have that feature and you will have to enter them manually.
alright - I have gone through and done an EQ for a single speaker, measuring in REW and creating some filters that it predicts should get the measured curve close to the target curve, then entering those into the mObridge software. Then I re-measured, and... it doesn't look much different. Even with some really significant magnitude, some major attenuation, it seems to only do 1/4 of what I was trying to get it to do. I'm getting a bit frustrated...
Update: I think using REW and calculating correction curves and typing the calcualted filters into the mObridge software is not really the way to go. I didn't get good results that way. It's more about just having a target curve as a visual goal, and then adjusting various EQ points live via the mObridge graphical interface until the line in REW RTA gets kinda close.
I've done that a few times, and it's really interesting how _far_ from flat the base speaker curves are. I do have very basic speakers in there, I put in the Alpine S2-S40C component speakers in the dash because they are very cheap, I could test things out. I still have the JL C2-650X in the kick panels. They are rather egregious - extremely boomy and bass-heavy. Maybe it's the location, maybe I blew the tweeters, maybe they're actually that way?
So - I don't feel like I was getting as close to the target curves as I'd like, but I was able to improve things quite a lot. And, of course, setting the timing and the levels is a rather significantly useful starting point.
Tuning a few different times, fiddling, things sound different each time; so I don't feel like I'm getting close to ideal. My current hypothesis is that it'll take better speakers that have flatter response curves to get there. I can chip away at that over time!
thenewjs
Archie
Braptor
Need a little help with firmware update. Im getting the following error. Mac - Ventura
Did you ever get this sorted? I'm in the same boat now.
I'm running a w/ MAC Sonoma.
mObridge
mObridge
Fraser
Orange County, California
BMW e92 328
You need to use mObridge DSP not mObridge updater and it should all work
thenewjs
Archie
Braptor
Got it working. didnt know there was an updated mObridge DSP. Tried to update with the old one. Was able to update the firmware. Once the update is done does the bronco tune need to be reapplied? I ask because my system doesn't sound the same.
C24R
Ryan
Idaho
2026 Badlands Sasquatch HOSS 3.0 2.7L
Question for m0bridge:
Understanding that sound is subjective, how much improvement does your system add to the overall sound of the factory B&O without replacing any speakers? $1,800 isn't nothing and I don't want to sink that much into it if in order to get decent improvements in sound it's honestly going to take another $1,000+ in replacement speakers. Thanks!
23OBX2.7
AB Canada
2023 Bronco
You're gonna blow all the speakers,
$1800 in signal equalizing mono amp, loaded sub enclosure Audison AP woofers, coax, 6.5 and sound deadening and absorber DIY will sound amazing as is does in my B&O.
Don't even need my Audison DSP amp that's is classifieds.
C24R
Ryan
Idaho
Well, the upgrade would only blow the OEM speakers if you drive them too hard, but the m0bridge has gain pots so you can dial them down to avoid blowing speakers. I have heard others say that the stock speakers are fine and just underpowered by the OEM amp, hence upgrading the amp in quality and power seems to improve the sound overall. I am OK spending $1,800 on improvements in sound but not $2,800+. I'm too old to need the type of sound system I thought I needed in my 20s. đź‘´
My F-150 and F-250 B&O systems are nothing to write home about, so I assume the Bronco's will be similar. These Ford/B&O systems degrade the B&O brand IMO. B&O home stereos are amazing as are Mark Levinson, McIntosh, etc. Not sure why they all feel comfortable putting incredibly watered down systems in vehicles. Anyway...I'm diverging from my point.
23OBX2.7
AB Canada
2023 Bronco
Can always try and if blow just get new ones:)
C24R
Ryan
Idaho
SlightTrash
Kentucky
Has anyone powered the new Bronco specific MB Quart pods and components with a Mobridge A2B? I have the MB pods on the way and debating just going for it all right now.
gauss66
Dan
Southwest Florida / NC Mountains
2024 Bronco Raptor
Hello All - Can I get some of your POVs for my situation ?
I have a 2024 Bronco Raptor with B&O ( and MOD top ). I am going to spend a weekend doing soundproofing ( the Resonix kit - similar to what was done in this thread: https://resonixsoundsolutions.com/b...-sound-deadening-noise-reduction-installation ).
I am sound proofing to reduce the noise at highway speed - at least to make using my cell phone a little more tolerable for others on the line. I realize I am fighting the design of the Bronco - but will do what I can. I will also gummi pflege the top seals.
Given that I will gut the interior - I am considering adding the " K2 8.1.1 Channel DSP Amplifier – B&O A2B Plug-N-Play Kit Ford Bronco ". So here are a few questions:
1) For those of you who have done the install - how long did it take you. I am thinking I can cut that time in half given I am already removing the interior for the Resonix
2) I don't plan on upgrading the speakers ( at least for now ). I did this once in my older Porsche that has a Bose system, where I had a Helix amp added. Sounded great ! Has anyone kept the B&O speakers ? What master gain did you use on the Amp ?
3) Has anyone added any sound proofing to the Mod Top ?
TIA - Dan
TheDudeAbides
Does mobridge ever have a sale or provide discount codes? System is nice but very pricey!
mObridge
mObridge
Fraser
BMW e92 328
TIA - Dan
Sneak peak!
We just got done installing the next generation amplifier into a 2024 Braptor.
More power, lower distortion, next gen DSP. Wiring was cleaned up before the panel was put back on!
1) it is now optional to run the ACM harness. If you do not plan on upgrading rear pods to 6inch then you can leave the headunit running the center and rear pods and the zen amp DSP can control them. This means the only wire you have to run is the power wire <1hr job
2) this is exactly the install we did, we kept the b&O speakers and just upgraded the sub. Night and day difference and tune file is available!
3) can't comment as we did not.
Ford Bronco Hi all IMG_4662
mObridge
mObridge
Fraser
BMW e92 328
It's actually cheap when you think of the total system
- wiring and bracket kit
- interface
- competition grade 8 channel DSP amplifier
- 500w monoblock
All in one box!
Occasionally we do run a coupon however we haven't for a while due to stock shortages
TheDudeAbides
- interface
- 500w monoblock
All in one box!
Yes, it’s a great option. Didn’t mean to suggest it wasn’t worth the cost, just that it’s a fair chunk of change!
