Has anyone had cracking/problems with the painted hardtop?
5GENIDN
Joe
Idaho
It will be 3 years in August. Just turned over 15k.... I would have LOTS of scratches if I did not have PPF... But to answer the question, No leaks, No cracks, Everything is great... and yes I have the gunners hatch... and same there. I have had it out a few times and no issues....
Andrew Bynum
Los Angeles
21 Two Door OB Sas V6 AMB
The problem with the painted roof is that it’s painted. This is supposed to be an off road vehicle but in reality it’s just another grocery-getter for most people.
All signs indicate the Lincoln Bronco will do well.
Roger123
Roger
VA Beach, VA
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
The problem with the painted roof is that it’s painted. This is supposed to be an off road vehicle ...
That doesn't make sense. It's as if you are implying that if the top is painted then it isn't intended to go off road. If the paint was the barrier to going or not going off road, then Ford shouldn't offer any paint. Broncos should only come in primer to that fallacy.
Andrew Bynum
Los Angeles
It doesn’t have to make sense to you. It is what it is. A painted roof is objectively, irrefutably less utilitarian and instead pretty. That’s the obvious compromise here. But, of course, facts don’t matter to people clinging to an idea.
5GENIDN
Joe
Idaho
This argument is about definitions.....
You could say the exact same thing about body panels... Rock buggies do not have them... Because, well, they get beat up. Obvious compromise. Most of them you do not even need to drive on the road. SO... Is the top itself a compromise (in any form)? By your definition I would think so.
Sparkie
Massachusetts
Sold all my cars to buy the Heritage Bronco
Anybody with a 2 dr have leak issues with the gunner's hatch?
Nope.
I've had the hatch open several times.
If I remove the hatch while the Bronco is still wet from rain, I'll get a few drops from the gasket's groove -- but that's not a leak!
VirginiaHeritage
Frank
‘25 Bronco HE
True, body panels are for Starbucks runs. The only legit way to wheel your Bronco is…
Ford Bronco Has anyone had cracking/problems with the painted hardtop? IMG_1405
Paul's silver pony
Paul
SC
24 wildtrak bronco
I know there aren't as many out there as the MIC hardtop, but has anyone had problems with the painted hardtop like cracking or leaks? I'm sure they get scratches easier but that isn't the top's fault.
24 2.7 wildtraks 13k no issues but I keep a good ceramic coating on it. The bronco looks and drives as good as day one.
RickBadSas25
Rick
St. Louis
2017 Silverado CrewCab
Eight months and no issues. I did PPF the front two panels because I removed them occasionally when I have the hard top on. I run the soft top through spring and summer.
heavyD
Calgary, Alberta
2025 Badlands 2-Door
Ford couldn't make a viable case to bring the Bronco back if not for the mall crawlers. Based on Jeep executive estimates, 85-90% of owners use these vehicles as mall crawlers.
https://www.powernationtv.com/post/what-percent-of-jeep-owners-actually-use-them-for-off-roading
Red2000
2022 Bronco
Yeah I mean the MIC top probably slightly more utilitarian. For instance maintenance, like waxing and taking care of the paint, etc. MIC is basic, nothing fancy, just wash it with a sponge. But the MIC tops all seem to crack sooner or later so you could make an argument for the painted tops.
You could also make an argument that white tops are more utilitarian because these keep the temperatures from the sun lower in the cab.
It's great Ford gives us things like this to debate :)
Back to the OP question, have been eyeing the painted tops to see if they will develop cracks too. Not sure if they are just painting over a MIC top or it's altogether different construction.
Bmisk19
Ben
Canton, MI
22 Badlands 2Dr 7MT
It's a different construction, different plant, different supplier. It's an entirely different product made to fit an existing package.
Red2000
2022 Bronco
Yes 100%, it's almost completely all about image and a reflection of one's chosen personality. I would say that the majority of sasquatch bronco owners will never even use the diff locks or see much more than a gravel road.
Also consider that the average car sits for 95% of the time. The actual offroad scene with people going offroad is so small compared to the pavement princesses.
The nice thing about the bronco is that it can be many things to many people. Luxury or basic. Choose your flavor hoss 1.0 up to hoss 4.0.
