- First Name
- Nate
- Joined
- Jul 14, 2020
- Threads
- 71
- Messages
- 3,866
- Reaction score
- 9,685
- Location
- Sac-a-tomatoes
- Vehicle(s)
- Bronco, F150
- Your Bronco Model
- Black Diamond
Zero personally, but a handful on the Web that raise some concern. BB just showed his that failed on the road. The ones I have seen the housings were broken at the mount & a few the tube casting failed. As painful as it was to sit though the second video (nearing LB's annoyance level@Felix808 how many broken tubes have you seen? I am more worried about twisting the splines as that drastically weakends the shaft and not a visible failure. It would be interesting to see if the 29 spline cast Dana housing bolts on.
this is a very valid point. Aluminum elastic modulus is likely >2x less than the cast iron. Depending on what grade cast iron. So even without over stressing the tube, bending flex can be significantly greater. Along with some bearing tolerance slop the intermediate axle can get loaded more severely.He was also thinking the failures of the intermediate shaft were probably due to the flexing of the cast aluminum tube vice the cast iron.
What kills IFS is the tire suddenly gaining grip and transferring all of the force or torque through the chain. That is how you break things. Open diff does help, but the M190 still has a lower torque rating than the M210.It would be good to know if upgrading from M190 with FAD to the standard M210 is gaining any real advantage, other than possibly changing gears and adding front locker.
Maybe an unlocked M190 can go the distance if you don’t have to have the locker?
This is assuming the weak point is the actual gears. On a solid axle this is pretty normal as everything is down sized in relation to the ring gear. On our axles it looks like the M190 and M210 share some bearings, seals and hard internals. We already know running the front locker to much will kill the front end.What kills IFS is the tire suddenly gaining grip and transferring all of the force or torque through the chain. That is how you break things. Open diff does help, but the M190 still has a lower torque rating than the M210.
This approach will also kill SFA's so not just limited to IFS. Driving habits/ techniques have a lot to do with surviveabilityWhat kills IFS is the tire suddenly gaining grip and transferring all of the force or torque through the chain. That is how you break things.
When technology becomes too political...I struggle with technology, but it seems posts are vanishing.![]()
