Front locking differential
Mr. jer bear
jerry
Fort Simpson NWT Canada
I have an Outer Banks 4 door with a rear locking differential. I got stuck in my driveway three or four times this winter a locking differential would be nice.. wondering how a person would find out my gear ratios 4.27? so I can match the front with maybe a used one.... I know there's the cost of the differential and the pigtail but what else is involved? Is there gaskets and seals? How hard of a job is it?
Buying a winch and a new front bumper is probably more than the differential....lol is the sway bar disconnect a separate unit from the differential or do you have to have a special type of differential? Just trying to weigh out my options.
MNBigfoot
MN
Oldhippie
Barry
Santa Cruz, Calif.
All ”used” front locking diffs will be 4.7 ratio (only available in Sasquatch, ok non Sasquatch badlands also) and it is completely different front assembly and axles (m210)…only way they came…you can buy the assemby and axles from ford performance or Dana in different ratios but I don’t think 4.27 is available so a rear change would also be needed…good luck!
brxxx
2024 Bronco Outer banks
You can find your gear ratio by running your VIN. 4.27 is common on Sasquatch models.
To add a front locker, you’ll need the diff, wiring/pigtail, switch, gaskets, and gear oil. It’s not an easy DIY gear setup takes skill.
Rspayde
North Ga
2022 C/O Black Diamond
I really hope you are not running the OBX street tires.
That being said as others have stated you would need to match the front and rear gearing so it would be two diffs you are buying.
I would be willing to bet you can find a take off bumper or even a nice new bumper plus the winch and still be well under the cost of install, parts, and software needed to do the axle swaps.
Fordified1
Bob
Mid South Texas
Better tires and or chains are the answer. It’s gonna cost you a butt load to convert a Bronco with 4.27 gears to having a front locker, and then you’re going to find out that adding one tire pulling is not gonna help that much.
Fordified1
Bob
Mid South Texas
I need to see pictures of this driveway if a 4x4 with rear locker is getting stuck.
Tires are cheaper than getting a front locker.
Well he is in Canada. Snow gets pretty deep. He needs a tractor with a snow plow lol.
Robs
Rob
New hampshire
2023 Black Diamond
How about buying an eight dollar bag of oce melt for your driveway?
Mr. jer bear
Mr. jer bear
jerry
We get a lot of snow. The driveway is about 450 feet long. It's not paved or straight. lol and it's not very wide tricky to navigate when I plough it with the quad not all the stumps are out of the road.... myToyo open country III are a crappy tire when it's slick or ice, my KO2 were a little bit better.... I just put on brand new falcon's 35" so we'll see how they do..... I have an extra set of wheels when the Toyo's wear down, I'll get a dedicated studded snow tire.... I rerouted my driveway so we'll see how that does....
Mr. jer bear
Mr. jer bear
jerry
I do have a tractor a Ford three cylinder diesel. Only problem is in -30 or -40 below. It doesn't like to start......lol
I think we need to come to your house to do our snow wheeling.
But to beat the dead horse a bit more - yeah, adding a front locker means upgrading to the M210 FDU and new front axles, as well as re-gearing your rear end. You can find the parts used if you dig hard enough, and if you can do the work yourself it's not hugely expensive; but a good set of studded snow tires and a winch will be a lot cheaper. As would getting the stumps out.
