Features Disabled to Save Battery
Hornet
Ford Explorer
Just started getting this notice... my Bronco is a year old
Ford Bronco Features Disabled to Save Battery 605304FA-3B7D-4186-BC29-B870AB62D086
Hornet
Hornet
Ford Explorer
Just started getting this notice... is good due to recent update? Now o can't listen to the radio when vehicle is off
Dashboard display has this message.
Ford Bronco Features Disabled to Save Battery CB865031-30DF-451E-B974-D62705DD22DE
RagnarKon
Ford Bronco, Escape, Focus
Modern vehicles have a battery management controller (called the BMS in Fords) that monitors the voltage and current utilization of the battery. If the battery charge is too low it'll start turning off features, such as accessory mode, the FordPass mobile application features, Auto Start/Stop, etc. to ensure you can reliably start the vehicle and don't get stranded.
If you live in a colder environment this will likely happen more often, colder temperatures are rough on batteries. If you want to continue using the accessories without the vehicle running need a battery tender.
sunpro2010
22 Bronco Raptor (9-7 build day)
My bronco doesn’t do this but my F450 has done it since day 1 with 7 miles on it. Ford checked batteries and nothing.
Hornet
Hornet
Ford Explorer
I've also noticed when I open my door my interior lights dont come on.
RHeinz
Ric
Houston, TX
My wife’s Lincoln Navigator (2019) started doing this a couple weeks ago. Changed out the battery and no further issues. Same battery as the Bronco.
Admin: If you alter my post, at least have the courtesy to note it. EDIT BY ADMIN:….
Hornet
Hornet
Ford Explorer
There we go. Out to get a coffee and the Bronco won't start. 1 year old and the battery is failing.
Getting a jump from a Honda - horrible.
I'll stop by the dealer. It should be covered.
The original battery in a conventional Ford vehicle will be covered by their New Vehicle Limited Warranty for three years or 36,000 miles—whichever comes first. Ford Hybrid batteries will be covered for eight years or 100,000 miles.
Lifeliberty
Moonbeam👀
Columbus, OH
I carry a jump pack, works great. I think it was like 45$.
They'll should test the alternator too, make sure they do
Lifeliberty
Moonbeam👀
Columbus, OH
I want to say i have this one, it's small and has a case. Works well. So well i bought one for my dad. He had to use it twice the past year and he said it worked great as well for him.
I had a battery dying on my previous car. Self jumped it twice to get to napa for a new battery
I also carry jump cables in my car, but this is a lot easier, plus can use alone.
I have fordpass and AAA as well, but this is so much faster
You are responsible for keeping it charged, but mine holds the charge really well. So maybe top up quarterly and after use.
I also use a battery tender during cold snaps and there are days i just don't drive so I'll hook it up.
I get pretty far on lead acid batteries. Best thing health wise for them is to keep them charged up(but not overcharged)
https://m.audew.com/Audew-1000A-Pea...4_5L-Diesel-Engine-p-100064.html?rmmds=search
Probably where i first saw it
Post in thread 'Budget Gear that Surprised you with Being Quality?' https://www.bronco6g.com/forum/thre...sed-you-with-being-quality.32166/post-1078445
Hornet
Hornet
Ford Explorer
If your battery goes dead the Auto Up Window feature won't work and needs reset.
Ford Bronco Features Disabled to Save Battery 048936FC-3C4C-46E1-B07D-3A47ED747F95
Felix808
SRV CA
Sounds like you need a battery tender.
I get the same message when I open a door & it wakes up, even though mine stays on the battery tender.
Rjacks258
Randy
Punta Gorda, FL
2022 Ford Bronco, 2019 Ford F250, 2009 Ford Ranger
Forum Nazis is more like it.
ksdon
kansas
Thanks for reminding me about this. I got the same message yesterday and plan to put battery charger on this evening.
