Factory wheel & tire weights - All Models
Dad life
J
TN
Jeep, Tundra, GX470
One question I haven't seen answered - has anyone reported the country of origin for the Sasquatch wheels?
I was pretty disappointed in the quality of the finish on my OBX wheels, and was pretty surprised to see that they were stamped "Made in China" on the backside. Coming from the Toyota world mostly, where factory wheels are often very high quality, it makes me question if I'll keep my Sasquatch wheels when my 2 door comes in.
EveryDayBronco
Motorcycle
Would it be possible to add all the offests to the wheels as well?
It would be a one-stop thread for information on the wheels.
Base and Big Bend, have 55mm offset.
I'll add that to the first post. The other wheels I'll need others to share that with me to include in summary.
BroncoAZ
Mitch
- factory wheel + tire = 57.5 lbs
- factory tire 30" dia, Bridgstone Dueler H/T 255/70R16 = 31 lbs
- factory steel wheel: 26.5 lbs
- wheel offset: 55 mm
Sasquatch
- factory wheel + tire = 88 lbs
- factory tire 35", Goodyear Territory MT LT315/70R17 = 54 lbs
- factory wheel: 35 lbs
- wheel offset: ____mm
- factory wheel + tire = 58.25 lbs
- factory tire 32" dia, Bridgstone Dueler A/T 255/75R17 = 35 lbs
- factory aluminum wheel: 23.25 lbs
- factory wheel + tire = 74 lbs
- factory tire 31.6" dia, General Grabber A/TX 265/70R17 = 44 lbs
- factory steel wheel: 30 lbs
- factory wheel + tire = _____ lbs
- factory tire 32.1" dia, Bridgstone Dueler A/T HRS 255/70R18 = 39 lbs
- factory wheel: _____ lbs
Badlands with bead locks
- factory tire 32.8" dia BF Goodrich KO2 AT 285/70r17 = 58 lbs
- factory wheel: 30 lbs
Wild Track
- factory tire 34.4" dia, Goodyear Territory MT 315/70R17 = 52 lbs
Add the missing info if you have it, other models if you have it, and no guessing, actual measured or manufacturer's specified weight please!
Sasquatch wheels and Wildtrak wheels are identical except for the color of the rings, offset is +30 mm. The 315/70R17 Goodyear Territory tires are 52 pounds, Sasquatch wheels are 35.5 pounds for a total weight of 87.5 pounds.
https://www.bronco6g.com/forum/threads/sasquatch-wheel-and-tire-weights.24920/
The tire weight for the Badlands BFG tires in 285/70R17 is incorrect, according to BFG’s chart they weigh 50.3 pounds for raised black letter. The Badlands non beadlock wheels are 28 pounds each, not sure about the beadlocks.
Ford Bronco Factory wheel & tire weights - All Models 2C4BBC2B-7065-4D96-BCB5-083BDF6FF988
More data from this thread:
https://www.bronco6g.com/forum/threads/weight-of-stock-wheel-and-tires.20371/
Weighed the standard badlands and 285/70/17 KO2s today - 78lbs.
Tire rack lists the KO2 @ 51lbs
So stock badlands wheel is 27lbs for 17x8. Pretty light.
I saw on here 63 lbs on Black Diamond wheel/tire
I weighed the optional Badlands wheel (beadlock capable) with the BFG KO2 285/70-17.
It was pretty porky at 86.2 lbs. (shown with 33x12.5-15)
Documenting my observation here: Black Diamond original wheel with General grabber atx (265/70 R17) weigh 74lbs.
Like had been stated here, I found the optional badlands wheel with the 33" bfg to be 85.8 pounds. The regular badlands wheel and tire, about 79. The fuel shok 17x9 with an e rated toyo open country CT 86 pounds. And my latest Fuel Shok with the 35x12.5x17 Toyo ATIII was this. Which surprised me considering it's also 10ply. That I believe is lighter than the sasquatch wheel and tire set up with a tire that's about an inch taller and more robust.
WorkBronco
WB
Boston
Sasquatch
- factory wheel + tire = 87.5 lbs
- factory tire 35", Goodyear Territory MT LT315/70R17 = 52 lbs
- factory wheel: 35.5 lbs
- wheel offset: 30 mm
- factory wheel + tire = 80.3 lbs
- factory tire 32.8" dia BF Goodrich KO2 AT 285/70r17 = 50.3 lbs
Badlands without bead locks
- factory wheel + tire = 78.3 lbs
- factory wheel: 28 lbs
Wild Track
Maybe someone with BD tires can confirm but my understanding is OEM is the LT version and possibly >50 lbs each. The 44lb version would be P version
rmillermich
f150
Perfect, made the decision for me. With all the takeoffs out there, I should be able to just buy a set of BB takeoffs to replace the stock. $500, done. Less than a pound in each corner. The Volk and 33s can wait....
Gambitl7
2014 Altima
Does anyone know the weight of the Everglade’s wheels? I like the look but if they are insanely heavy I'll skip.
Aonarch
Jack Hoff
MT
Heavy AF. 36 pounds.
Also the badlands beadlocks are 35 pounds, barely any different between them and the larger 8.5" on the sas.
mpeugeot
Yes, they are the LT tires.
darinhouston
Darin
U.S.
Bronco, Jeep Wrangler, Bronco Sport, Pallisade
what about non-SAS Badlands standard wheels?
Deleted member 64921
Guest
I know this is an old post BUT - Does anyone know the weight of the 17" alloy BD wheel ?? (not the steelies)
CalvinT
Calvin
Phoenix, AZ
Probably about the same weight as the Big Bend wheel, 23 lbs. It's also 7.5 inches wide like the BD wheel.
SHANUT
Craig
Hermann, MO
My 0 offset Mickey Thompson 17 x 9” wheels are 19 pounds lighter than the stock Badlands Sasquatch 17 x8.5” wheels they replaced. That is crazy to me.
Ford Bronco Factory wheel & tire weights - All Models IMG_1925
Ford Bronco Factory wheel & tire weights - All Models IMG_1882
