Factory wheel & tire weights - All Models
Deleted member 64921
Guest
My 0 offset Mickey Thompson 17 x 9” wheels are 19 pounds lighter than the stock Badlands Sasquatch 17 x8.5” wheels they replaced. That is crazy to me.
And they look 19 times better 😂
How is the zero offset working out, I gotta admit, I'm leery of going zero offset
SHANUT
Craig
Hermann, MO
I have a set on my Badlands Sasquatch, and I also have a set on my Badlands that was not Sasquatch and I like the zero offset on both of them. Zero offset on the Badland Sasquatch basically takes the tread out even with the edge of the fender flares which to me looks much better than the weak stance they come with from the factory. And I really like it on the Badlands because the tires are actually wider than the fender flares by an inch and a half or so. People are always worried about tearing up their paint when the tires stick out past the fender flares but anything that’s out past the fender flares is not going to throw rocks on your vehicle anyway because the vehicle is inset quite a distance from the outside edge of the flares. One of my Broncos is a couple of years old and the paint is still perfect with the zero offset wheels.
Steve_In_29
St Johns, Arizona
2024 Heritage Limited, 2 Door, 1973 Bronco, 1999 Ranger, 2007 F350
19 pounds lighter per wheel?
How do you figure?
Bad/Sas/beadlock = 35
MT = 21
Gives a difference of 14 pounds per wheel.
swamp2
Are these figures (at least in the OP) spec values or weighed by a member here values. Most people don't have accurate enough scales for the differences.
My factory Raptor, non bead lock capable wheels: 30.75 lb
Factory 37" K02 tires 73 lb (Bridgestone spec is 65 lb)
Very accurate, trade legal, load cell based scale .
Steve_In_29
St Johns, Arizona
What size BFGs are those?
