Factory Fog Light Switch
Bill K
Allen, TX
Ford Bronco Big Bend 2 Door
A lift makes it so much easier, you can pull the wheel and liner easily, and work comfortably that way! I can't imagine doing that wiring on jackstands, Your neck would be sore after 30 minutes :)
Well, my 1 week morphed into 2 on my buddy's lift, but I got er done. Very happy with the results (also did flat tow wiring and adapter install too). Much more soldering than I anticipated, but there it is. Thanks again for all of the support!
Ford Bronco Factory Fog Light Switch Bill Flat Tow Front Pictur
Bill K
Allen, TX
Is anyone who added a factory fog switch to the MOD bumper using a relay or are you all just tossing in those three pod lights per side with a hope and a prayer the amperage is good to go?
I just ordered my module and plan to install fogs at C203 front and C424 rear. Wondering if I'm going to have a funny burning smell at some point unless I use a relay.
I just finished my 3 pod light install. I used the factory harness from Diode Dynamics with the relay for the off road lights. I took Zuke's advice and wired in the fog lights to the ford wiring after replacing my factory switch. When I turn on the 3 way switch that came with the 3 pod light set, all lights come on (I assume through the relay system). The switch allows for all lights on in one position, or back lights on in the other. When I use the factory switch, only the fog lights are on. No burning smells ;). Hope this helps.
akerman1
Rusty
GMC Sierra
My issue was resolved. I restored original forscan settings and redid them and works now.
I am having the same issue, no power. What should we expect with a volt meter when the factory fog switch is on?
zuke
Stafford VA
Battery voltage, 12.5 or so volts
zuke
Stafford VA
That is what I thought I am getting nothing. Is it possible that the settings in forscan module for 2023 changed ?
It is possible, although I haven't heard of any changes..
nwGTS
Nate
Chicago, IL
Does any one have an actual picture of C424 (not diagram) for the rear fog?
I've seen the diagrams. I want to see the actual connector.
My new module with F/R fog is installed. Ready to install the rear trail lights and want to tap at the connector... not the white/blue wire running back under the driver's side door molding.
Gotchaa
Los Angeles
Tesla
My Front and rear module is installed. Ready to install the rear trail lights and want to tap at the connector... not the white/blue wire running back under the driver's side door molding.
looking for this too, do you have the front factory harness? If so can you test out voltage your are getting and share changes you made in forscan.
I ran into a bug where I enable 726-01-02 front fog light indicator using “80” to enable and it disables the brake light indicator, repeatable.
However my switch button still works and I see it eluminated.
nwGTS
Nate
Chicago, IL
No front harness, I'm tapping the front at C203. Sorry, not sure how to help and don't want to create noise by speculating.
Bad_Bronco
Peter
Port Coquitlam, BC
1963 Chevy Nova SS, 2021 Ford Bronco WildTrak
Did you ever get this figured out? I’m having a similar issue.
BCM needed to be switched on for the fog lights to work. Need to do that in Forescan. Once that was added, the fog light switch and lights worked perfectly.
nwGTS
Nate
Chicago, IL
Here are a few extra steps for those with rear fogs too:
I installed the Front/Rear Switch today and used steps described in this post to activate in FORScan.
In addition to the BdyCM steps in that thread, I needed to Enable the rear fog lamps, DRL Fog, fog with highbeam, rear fog with trailer and a few others in the BdyCM since I also had the rear fog and wanted to use the fogs with DRL.
I also Enabled rear fog in IPC.
In BdyCM Instead of the '0101' config, I went with '0303' which lets me use the fog with DRL and turns on the respective side when cornering.
Everything works exactly as it should on the dash but I still need to install my lights.
With these changes, both the Rear and Front fogs will operate with only the DRL which is the best option for dusty and snowy situations where you ONLY want yellow lights.
Note that the rear fog (which I'll use as a trail light) works with DRL on only if the front fogs are also on.
Ford Bronco Factory Fog Light Switch IMG_5877
Ford Bronco Factory Fog Light Switch IMG_5878
Gotchaa
Los Angeles
Tesla
Good info, thanks for sharing. I have the CC model of the dual fog switch. I think the BCM coding 0303 may be why I was not detecting power. I am going to check this today.
When you do get to wiring to the rear fogs harness, please take pictures of where and how you tapped in.
RFMETZ
Ryan
Lakewood, CO
GX460
Any luck on this? Having the same issue, not sure where I need to make changes.
Gotchaa
Los Angeles
Tesla
yes for the front fog, I finally did get power to the factory fog harnesss by changing the coding to what nwGTS reported, using 0303. I knew it was going to work right away because I got open circuit DTCs for the front and back fog lights.
I am waiting for some y splitters for my ground, then will make my pigtails to connect the white fogs to the factory harness. As far as the rear switch and harness, I have not tried locating or tapping into to it yet, I do have it enabled though.
