Factory driving lights going off & on
Barneyridesagain
Deep in the heart of
'22 Bronco, '20 Trail Boss, '18 Triumph Tiger
Has anyone had issues with the factory driving lights randomly going off and back on while going down the road. Ours seem to turn off for a few seconds and then come back on without any pattern. It's not a flicker like a loose connection. When they go off they stay of for 15 to 30 seconds?
The light sensor is very touchy and it doesn’t ramp up and down very smoothly. So if you are driving and you go through a shadow or a cloud goes over head - not sure if that is what you are seeing or not. That controls the backlight on the internal displays and the headlights in auto
Headlights also turn on with the wipers, but there is a bit of a delay there - it takes one or two wipes before the headlamps kick on.
Arokcrwlr
Kraig
US - Alabama
Are you talking about the headlights or fogs? If you talking about the fogs - check to make sure the plug under the drivers side bumper is tight and making a good connection. My fogs did exactly what you're describing from the moment I drove it off the lot. I checked the connector and the connector was not pushed to lock...
Barneyridesagain
Barneyridesagain
The fogs are what I was talking about. I'll check the plug. Thanks for the heads up.
Barneyridesagain
Barneyridesagain
Thanks but I was actually referring I guess to the "fog" or "driving" lights in the bumper.
Todd H.
Todd
Castle Rock, CO
Lincoln
Fog/Driving lights are programed to turn off when the high beams are activated. So if you have automatic high beams they will turn on and off with the high beams as you drive.
Barneyridesagain
Barneyridesagain
That's a possibility since it usually happens when going over a hill now that I think about it. Didn't realize it even had that feature. It's an OBX with high package. Will have to check the features.
Thanks!
helifino16
Ron
Mount Sinai, NY (Long Island)
If you have access to ForScan, you can set the Fog Lights to stay on with the High Beams (sometimes referred to as Bambi mode).
You can also disable the Auto high beam by cycling the turn signal stalk forward twice.
Ford Bronco Factory driving lights going off & on 1734539490199-kh
You can keep the Fog lights on by suppressing the high beams.
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
Thanks!
It’s not a feature. That’s pretty much just how headlight systems work. Even if they’re not automatic systems. High beams go on, fogs go off. Since you shouldn’t run high beams in fog, there’s not reason for fog lights, right?
BlueWaffle
Maine, USA
2023 bronco, and a trio of 80s GM's.
Factory fogs turning off when the hi beams get turned on is federal regulation.
mikec426
Russellville, AR
How about that! Mandated common sense.
(That post is in no way political, I’m just being witty. Or trying to at least.) ;)
BlueWaffle
Maine, USA
*Laughs in lawless button box* 👹👹👹
Ford Bronco Factory driving lights going off & on 1000000205
