Driving/fog lights question
Rickap7
NJ
25 Bronco
I have a 25 Big Bend with standard bumper no fog lights. I want to add fog light to bumper. I want to be able to have them work like they where factory installed what do I need to do? I know I will have to purchase a new OEM light switch with driving light button. but what else do I need? Do they sell a wiring harness that will allow the use of factory light switch w/driving light option?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
You don't have fog light wiring sadly there. I don't even know if you can add it easily to be honest. Unlike the trucks with mod bumpers, that have a hidden pigtail (sometimes). The base trucks with plastic bumpers and no fogs have no wiring at all there.
You CAN add fogs if you get the OEM fog light brackets from Ford and then an aftermarket fog kit. But you'd need to wire it to a switch
Motovita
WA/AZ
25 Bronco
My Badlands came with the Modular bumper. Where should I look for the hidden pigtail?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
If it's a 2025 it won't be there. 2024 and earlier look behind the plastic cover around the front tow hook. It'll be under the tow hook
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Motovita
WA/AZ
25 Bronco
Thanks, you saved me some searching time. What I think I need is a single fog/visibility light to mount roughly centered in the opening of the modular bumper. My state requires a front license plate and I plan to mount the plate where it would partially block the inboard light on any of the multi light setups I've seen for that bumper.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Just use our license plate bracket: https://www.4x4truckleds.com/kr-off-road-license-plate-bracket-for-2021-ford-bronco/
This way you can mount 1 2 or 3 lights per side in the fog pocket and not block anything.
Additionally you won't run the risk of blocking any parking sensors with a plate mounted to the outside of the side of your bumper.
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
This license plate bracket works great on the standard bumper. No drilling required License Plate Bracket
