Extra letters on Nav screen
Tor148
Tor
Cape May Court House, NJ
23 Braptor Bk, 21 FE RR, 15 F250,
I noticed this a little over a month ago, but then my bronco was in the shop for about a month.
I use Android Auto constantly so I am not sure whe it started.
When i go to the Ford Navigation Screen there is extra text.
Ford Bronco Extra letters on Nav screen 20230813_134352
She is a 2 door First Edition, that i have since new.
I used Forscan about a year ago to get rid of double honk, add sport mode, bambi.
The last over the air update was July 12th 2023.
Anyone have any ideas??
Ford Bronco Extra letters on Nav screen 20230813_134325
Ford Bronco Extra letters on Nav screen 20230813_134414
Ksjrb03
Tx
F250
Do a hard reset. Pull the sync fuse is my preferred method. You can also do a button combination on the head unit but it doesn’t reset all the modules. I think it’s play and skip forward button until it resets.
Tor148
Tor148
Tor
Thank you for the suggestions I tried both things and neither worked
bradcd
Brad
Saab 9-3
Can you switch the infotainment's language setting? I forget. I'd try to switch to something else then back to English.
JediMcMuffin
Tommy
2021 Bronco Badlands
Someone else posted this a while back. It happened after an update that must not have applied properly.
Hunterwjusmc
Tampa, FL
2026 Bronco
I had this same problem. I figured out that it happens if you make the forscan change to switch the country code from U.S. to Canada so that you can get NAV in motion. (Basically being able to enter an address into Nav while in motion). Switching back to U.S. will fix the problem.
Tor148
Tor148
Tor
Ahhhhhhhh, that makes sense!!!
I did that not that long ago and forgot.
Thank you very much!
CarGuy
New Jersey
2023 Ford Bronco
Looks like Biden’s teleprompter 🤣
Agrod
SJ, PR
22 4dr OBX
This. I had to revert the Forscan Nav in motion as well. Same issue.
