Exploded Steering Rack
rugedraw
Javier
Miami, FL
2021 Ford F150 Platinum FX4 EB/2023 Bronco Sport Badlands/1991 Mustang 5.0 coupe
Ducati1098
I'm certain the physical rack will work, I've used both the FP Rack and the Stock 3.0 Replacement rack interchangeably with FDRS. At least in what I see on line right now, The FP Kit is actually cheaper than an off the shelf replacement rack, So I've switched over to those.
I'm not so sure the ProCal is gonna be able to program a rack in a vehicle that already has the 3.0 though. It ought to be able to, but until someone actually does it, I'm gonna remain skeptical.
I have two unused ProCal vouchers if someone wants to try it :D
Yeah I have no doubt the rack will work, just not sure the procal can do the programming
NC_Oak
2024 4 door 2.3 sasq
gunna follow this one to see how 3.0 rack replacement programming goes now a days
broadicustomworks
Hanging Rock, North Carolina
FWIW WildHorses sells an already-programmed SD Rack with the HD tie rods, ready to bolt in and go.
It is not available on their site that I can find any longer but if you call they will be able to "Steer you" in the right direction.
The one I bought was about $1900 shipped. Literally bolted it in, plugged it up, and got an alignment.
(209) 400-7200
bendover
bendover
2018 M2, 2025 Bronco
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
(209) 400-7200
Because they came from Broncbuster and he went under.
BAUS67
redneck
Central PA
Sent it a bit too hard. 😁
BAUS67
redneck
Central PA
Motovita
WA/AZ
25 Bronco
Correct. The FP steering rack upgrade wasn't designed for a vehicle that already came with it from the factory. You just need FDRS.
The FP rack upgrade kit is only for the following vehicles:
  • 2021-2024 2Dr Bronco (all models) are compatible
  • 2021-2024 4Dr Bronco (all models) with Sasquatch package
  • 2024-2026 4Dr Bronco Non Sasquatch (including Badlands)
  • 2021-2022.5 4Dr Bronco Wildtrak® (without HOSS3.0) Package
  • 2025-2026 2Dr Bronco (non Sasquatch)
  • 2025-2026 4Dr Bronco (non sasquatch)
Edit: Actually now that I look at that list, maybe it will work.
Because it shows 24-26 4Dr non-sasquatch including badlands, and a non-sasquatch badlands would already have the 3.0 rack. Unless that is just a mistake 🤷‍♂️
I was under the impresssion that my 25 badlands 4 door non squatch came with the heavy duty steering parts. Did I get that wrong?
Ducati1098
No. It should have it
CalvinT
Calvin
Phoenix, AZ
Why don't they make it for 2021-2023 4Dr Bronco w/o Sasquatch? They make it for every other Bronco.
CalvinT
Calvin
Phoenix, AZ
