Engine is not idling smoothly
Arnold1
Los Angeles
Maverick
I just got my 4 door 2.3L OBX. I like the engine, plenty of power. I have only 50 miles on but noticed when I stop at red lights, that the idling is not smooth at all. It seems that there is some fluctuation of the RPM, (but the RPM gauge is not moving). I thought it might be from the power pull of the AC, so I turned it off but nothing changed. Any idea what it could be? Thanks in Advance
Lifeliberty
Moonbeam👀
Columbus, OH
You're at a light, so stopped, for on brake, ASS trying to kick in? your ac was on so it shouldn't. Bad gas?
I have a stick and never experienced that. Start with the easy things first, voltage?
The tach sucks, i don't trust it for little things like that, half the time i think it's just for decoration, i go by sound
Arnold1
Los Angeles
Maverick
Yeah, no ASS. Bad Gas or just initial break in of the first 100 mile? It is definitely not a normal engine feel. I will run the next tank with premium gas to see how it goes.
Lifeliberty
Moonbeam👀
Columbus, OH
It could be a ton of things or nothing😅
‘21OBX
90Bronco19
2022 bronco outer banks
My 2.7 idles rough for sure not sure I’ve noticed it on our 2.3 yet. I think it’s partly how low they have the idle set from the factory.
mbagne
Placentia, CA
Mach-E GT
Could it be the fuel pump? There are a few threads out there with folks getting caught out on the trail with a dead Bronco due to the fuel pump. They reported the engine running rough and spotty before eventually dying. Diagnosis was faulty fuel pump.
DEC
Derek
SoCal
BMW 640, Mustang Bullitt, Mazda 3, Honda Accord,
My 2.3 is smooth as silk.
Arnold1
Los Angeles
Maverick
I hope not but I will have an eye on it.
BTW: While I think the 2.3 has more than enough power for the Bronco, I think the brakes are terrible. I have seen many reports comparing 2.3 vs 2.7 and the 2.3 Brakes have been reported to be the weak point of the 4 cylinder. I can definitely confirm, not boeno at all....
Campbech
Ohio
Nissan Titan
I have to say I am having the same problem with my OBX. I noticed it when stopped at lights. It kinda seems like a sputter or something.
mohitdp
Mohit
Dubai
Were you able to figure this out? Mine has been doing the same for a while now and the dealer claims its normal.
Oilbrnr
Scottsdale, AZ
'97 factory locked LX450, '16 Power Wagon w/FWC, '25 Bad/Sas/7MT
At only 50 miles the ECM could still be adjusting fuel trim levels. If you read the manual, it says to expect some engine oddities for the first 100 miles (and probably x-number of key cycles/highway cruising events). If you have a OBD-II reader, see if there are any pending codes.
Valhalla
Valhalla
Chattanooga Tn
Completely agree with oilbrnr, it is the ECM learning. All modern vehicles I know of learn adaptively.
mohitdp
Mohit
Dubai
Mine is way past the 50 miles, I'm close to 50,000 kilometers but still have this issue.
zuke
Stafford VA
I'm assuming it's a '25 if you just got it, which should be electric boost instead of manifold vacuum, and that was supposed to resolve the weak 2.3l brake issue...
But I haven't heard a lot of talk from people running the new setup yet, I hope it's not going to be a continuing problem for the 2.3. :(
Valhalla
Valhalla
Chattanooga Tn
Yeah, but it's not your post; start a different one with all your particulars and I promise we will armchair diagnos the $#!t out of it!
