Engine Running Hot?
NotApplicable
BEVs
As a couple folks correctly recognized, it is the oil temp at 212F, which is perfect, boils off moisture in the oil. The real concern is the trans temp, 205F is 15F higher than I would like to see under normal use.
This has been discussed extensively elsewhere but all signs point to this being normal operating temps for the 10R fam
206-215 has been pretty widely reported as normal observed temps for the 10R80 in the f150, and the ULV ATF specs seem to support this band of temperatures being normal
goatman
Richard
Bakersfield
'22 Badlands 2 dr 2.3L, 2000 Ford F450 PU, 2001 Jeep Cherokee
At 77 degrees, Cruising at 75 up a slight hill, the water temp shot to 212F and climbed to 218 then back down to 208 for the rest of the 1.5 hr trip. I am used to seeing stock engines run around 185-190. Does anyone have this engine running kinda hot for you?
Modern cars have thermostats that are 195-200. Aux fans come on around 212-215. Like has been said, to get emissions and fuel economy modern engines run hotter. Watch it, but I wouldn't be concerned.
SuperDave150
Lubbock, TX
Ford F-150, Ford Edge
SuperDave150
Lubbock, TX
Looks normal to me. If you are worried about it just continue to check the temp at the end of every one of your drives to compare but I doubt there will be much of a difference as long as there isn’t a leak
Yup. Normal.
West1
DM
Atlanta
Bronco Base with OBX wheels
What does the owner's manual say is the normal operating temperature? Completely different vehicle, but for my Jeep TJ it is 210 degrees.
My JkU also runs between 205-210.
dgorsett
colorado
F250, Mustang, Explorer
Yep, every Jeep 4.0 I've been around runs 210 all day.
Flourman
Centennial, CO
2022 F350 Tremor, 2019 Beta 300RR
As everyone has said, throw what you know from older motors out the window. The newer motors will run warm and stay there. 220 water temp is pretty normal. I towed all over in my F150 3.5EB with water temps running 235-240. The computer pulls boost around 250 to save the motor.
transmission temps are the same. They will run hotter than what you’ve been used to seeing but they will just stay there.
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
If you’re really concerned, @Mishimoto will eventually make a lower temp thermostat, also there’s that company with the vented hoods (forget the name, sorry) and eventually a fmic and charge pipes as well.
Plus summers over, it’ll cool down as well
Techun
Pa
BD, 2.7, MIC, 4dr
Under normal conditions - and not towing anything - that shouldn't happen. I've gone up some really long steep grades - e,g., Baker & Tehachapi grades - with my JL's 2.0T in 115 degree heat and the coolant temp hasn't changed a bit. Rock solid @ 192 degrees no matter the air temp, on road and off. Newer engines shouldn't fluctuate much under normal driving conditions.
If the number never changes, they're lying to you
AZ_Liberty
2007 Expedition
Random, but I cover Phoenix in my territory and always wonder how much everyone blasting their AC affects the overall outside temps when hot air is expelled.
The biggest issue is the heat island effect from all the concrete. Drive across a wash or other slightly open area at night and your outside thermometer will show up to a 10 degree drop.
BaseBD
Missouri
2021 4D Black Diamond
The 2.3 seems to like running warm. I spent ~25 mins running up 3 - 9 degree grades in 1st gear, low rpms off road earlier this week. Oil temp started at 215 and slowly crept up to 223. Was there for a while before I got to the top. No lights, no warnings. Appears normal and to be expected. Performed as expected.
BroncoKing610
NJ
2021 2.7L Bronco
2.7L 90F outside going 75mph I had 225F for engine and 205F for trans, never went over and whenever I went off cruise control to slow down it usually almost dropped instantly to 223F
