Engine Running Hot?
GrabberBlue
Phoenix, AZ
2010 F-150 Raptor, 2021 Bronco FE
The 212 temperature value you're referencing is Engine Oil Temperature, which runs hotter than Engine Coolant Temperature. You don't need to start sweating until you get to 245 degrees. I have had my GT350 up to 255 degrees during the middle of the Phoenix summer (110+ degrees ambient) in low speed traffic with the A/C blasting without worry.
FlyingBronco
The Don
Orange County, CA
Random, but I cover Phoenix in my territory and always wonder how much everyone blasting their AC affects the overall outside temps when hot air is expelled. Everyone worries about fossil fuels or whatever but AC is blasting all day everyday… cars, homes, businesses. The more people, the more AC, the more heat created, the more AC, and so on.
uncledoodoo
Everglades
00 XJ, 56 F100, 11 Volvo XC90, Everglades
Everglades
I'm glad I read to the end before I posted the same thing :)
GrabberBlue
Phoenix, AZ
That's part of one of the biggest climate issues in Phoenix, the heat island effect. Like you said we have A/C systems discharging heat, concrete & black asphalt absorbing and radiating heat and very little vegetation to provide cover to the ground below.
NewBroncoOwner
NewBroncoOwner
Good Ol USA!!!
2021 Ford Bronco Base
ok now thats a stupid oversight on my behalf!!! good catch, thank you!!!
MayhemMike
Mercury
The “ heated air” you reference is air that is already heated. AC units simply move heated air from one location to another. Technically, a micro fraction of heat from the mechanical energy converting into thermal energy is produced by the compressor, but the heated air is simply being transferred through the process of refrigeration.
FlyingBronco
The Don
Orange County, CA
I am not sure your point makes sense. A place like Phoenix was never naturally 65-70 degrees in summer months, so the heat expelled to cool an indoor space will definitely create a greater heat effect outside.
dweskamp
Dan
Missouri
2016 GMC truck
I let it sit for about 30 min after getting home and looked to bleed the coolant system, but no bubbles. all fluids are right where they need to be and no chocolate milk in oil...had to check for S&Gs.
Call your dealer and ask, there is also a Ford Tec thread answering questions like this
Bob 07064
Bob
Somewhere in time and space
02 4x4 ranger, '17 edge 2022 Bronco
All this science, I don't understand...
Ford Bronco Engine Running Hot? favorite-facts
Blue's B6G
Jeremy
Los Angeles
2021 Bronco OB 2-Door V6 Sasquatch AMB High Pack
I've gone up some really long steep grades - e,g., Baker & Tehachapi grades - with my JL's 2.0T in 115 degree heat and the coolant temp hasn't changed a bit. Rock solid @ 192 degrees no matter the air temp, on road and off.
Wrong vehicle.
George Ellis
George
Cumming, GA
23 Bronco Badlands Soft Top
The net change is close to zero. The fault occurs if you measure outside near a heat 'exchanger'. The energy used to exchange the heat does become becomes part of the UHI.
Drex
Jake
As a couple folks correctly recognized, it is the oil temp at 212F, which is perfect, boils off moisture in the oil. The real concern is the trans temp, 205F is 15F higher than I would like to see under normal use.
