engine break in
T800
Rick
Riverside, CA
OBX SAS Avalanche Gray
Two weeks ago, I picked up my new Bronco Badlands with the 2.7L. I have purchased dozens of new cars/trucks, gas and diesel, in my lifetime. I treat the engine carefully for the first 250 miles, and then I drive it as normal. I've never had an engine that burned oil or had any other issues.
I picked up the Bronco in Denver and drove it to St. George, UT. As soon as I hit I-15, I was up to 80 mph, the speed limit, all the way to St. George. The Bronco ran like a champ, and not one drop of oil was burned.
I'll change the oil and filter at 1,500 miles, and then every 3,000 miles thereafter. Clean oil = long engine life.
Take the above information as you wish. I can only say it has worked well for me.
PS. Never trust the Ford manual when it comes to fluid changes, engine, transmission, and rearend/frontend.
Maybe 3K miles if you're using conventional oil.
I will use synthetic which is where the 10K figure comes from. I will change it early the first time, but will change around 6000 - 7000 after that.
I feel like they say 10K figuring you will need a new vehicle sooner.
McRightclick
Idaho
2026 Badlands 2DR 7MT
One thing I haven't seen mentioned yet is don't be afraid to build up a little cylinder pressure to help seat the rings. Get some boost and throttle going up a hill (obviously don't lug it, though) but keep the rpm reasonable.
Once mine gets here, I'm going to do an oil and filter change at 1000 miles with Ford's 5W-30 oil, then run that out to 5000 miles and switch to HPL afterwards.
thomasj2352
alabama
frontier
so I am three weeks and 700 miles in on my new ride
Ford Bronco engine break in IMG_5375
And so far so good except that I’m hearing rattling or clattering sound when it’s idling I’m not so keen on that. I’m gonna wait till 1000 miles to make the first oil change I think.. also I mentioned to the dealer that the Toyota dealers in this part of the country have special trim levels and wondering if ford does the same thing and he says what did you have in mind and I said how about a V8 and he said well, we’ll see what we can do and so that’s what they could do !
T800
Rick
Riverside, CA
I bought mine last Thursday and drove it 400 miles on Saturday. About 200 one way, then 200 back about 2 hours later.
I let my wife drive it, so we went as slow as humanly possible lol.
BaseModelCanadian
Sterling
Ontario, Canada
2025 Ford Bronco Base
At least mine nearly sounds like a diesel while idling, then quiets down once it switches fully over to direct injection. I wouldn't be surprised if the 2.7s are similar
timhood
Tim
Several
My 2.7 has always been quiet. I'll see about recording a startup for you.
jcartwright99
IL
2025 Bronco
I'm going through this myself right now. Got it with 5 miles and now how about 250. I have the 2.3. I have really tried not to punch it but I have had a couple foot to the floor moments. Been trying to drive it normal in eco mode going through rev range a lot (trying to keep it under 5k until 1000 miles). It's hard because it is my daily and am commuting in Chicago city traffic.
I'll change my oil at 1000-1500 miles and then drive it like normal ( which would probably be considered heavy duty use).
Since I've owned several Ecoboost engines, I have an opinion on a couple things. Trying not to go over 5k before changing your oil and only use a quality full synthetic. Never put in 87 octane, only 91+. Just one mans opinion.
Just because I need to share a photo. I’m not good at photography.
Ford Bronco engine break in IMG_6971
timhood
Tim
Several
Define high speed? ,)
That's suitably vague, isn't it? 🙂 I've always gone with "avoid high revs" rather than high speed, because what is wrong with (for example) 70mph in 10th gear vs. 35mph in 1st gear? High speed doesn't mean high workload if RPMs are in a suitable range: not too low to avoid engine lugging, and not too high to avoid drivetrain stress.
Notmattwong
Pilot Point, Texas
2021 Bronco Sport Outerbanks, 2026 Bronco Base
I got mine with 26 miles and had to drive about 50 miles home. I daily drive this thing in DFW so I can’t exactly take it easy going on public toll roads and highways. I changed the factory fill oil at 1200 miles and installed a fumoto valve. I plan to change it again at 5000 and do my first 5 wheel tire rotation. I’ll space it out to 7500 intervals afterwards.
SHOCALL
Joshua
MO
25 Bronco BadSaS, 19 SHO PP
Your logic is sound in my mind.
23OBX2.7
AB Canada
2023 Bronco
I always drive hard from day one change oil at 1000 then every 3000 miles and they always run like a dream. Always let engine idle 2-3 min after after any hard turbo use.
Vynull
Jake
Goshen, NY
2026 Bronco Heritage 4-Door 7MT, 2001 Saab 9-5 Aero Sportcombi
Automotive OEM Professional here (BMW, but doesnt matter in this case) Your engine straight up does not need to be broken in. All modern engines are broken in on a dyno, oil changed and installed in vehicle. Tolerances are super close, if the rings arent set by the time the engine meets the frame, your driving wont help them.
What DOES need to get broken in is your drivetrain. Gears need to mate, clutches need to bed in, brakes need to bed in. These are the reasons you dont hammer it. That said, there is a big difference between beating on your car, and helping things to mate together. The advice I received from our engineers was - Go on the highway, put it in 4th or 5th, and slowly add throttle and let it eat for 5-6 seconds. Slow down, repeat. This is loading up gears and helping them mate across different internal speeds.
Agree on the "dont use cruise control". But its not about the motor, its about the trans and rear.
