EasternSierra
Sacramento metro, California, U.S.A.
2025 Bronco Badlands 4-door 7MT, 2023 Ford Transit Connect van
...The Mickey Thompson Baja Boss A/T and KO3s are on my short list for my next off-road tire. The only downside is the MTs are E....
MT has 33/35/37" flotation sizes in D. You may need to search to find a vendor who has the size you want in stock.
ThunderFlash
Doug
Washington
'24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
I just looked and Tire Rack was not showing the 35x12.5-R17 Mickey Thompson BB AT in LR D, just the P315/70-R17 in LR E. They used to list the 35" in LR D. Discount tire shows the M/T BB AT 35" LR D flavor, though. I hope M/T didn't discontinue the 35" flotation model because I'm loving these M/T BB AT tires so far.
I'll spare you all my typical longer winded reply and give this medium winded reply. I vote LR D. With my heavy truck and at 22 psi, the 35", LR D, M/T BB AT worked really well in the limited trail miles I have so far. That pressure put the side bitters in position to do some work and it seemed I needed the rear locker less often. The tires are equally swell on the road. They manage the truck weight (as much as 6,200 lbs) much better than the OEM GY LR C tires, both on and off road.
Ford Bronco E load vs C load tires - what's your pick? PXL_20260527_190451436
EasternSierra
That's why I said you have to look around. The MT site shows 33, 35, and 37" flotation sizes. Tire Rack doesn't have the 35s and neither does another site I looked at. A third site (don't remember name) does have them in stock. Since they're still on the MT site I assume they're not discontinued.
ThunderFlash
Doug
Washington
I guess so. Just kind of odd that I had used Tire Rack to research tires about 4 months ago and the 35" M/T BB AT option was was listed. Always found TR had a fairly complete catalog, but lesson learned that due diligence in researching can pay off.
EasternSierra
I was really surprised when I went there and the 35" flotation size was missing. I'd copied the specs from that site months earlier. Like you, I'd always figured that Tire Rack would be comprehensive in its offerings.
OffroadCamper
Richard
San Diego, Ca
F150 Sport 4x4 5.0L 3.73 eLocker...totaled, Mazda 3 ST, Sienna SE
Great thread, good info. Thanks to all.
Convoluted dark marketing magic are ply ratings... LOL
I'm a E guy.
Our group doesn't require it, but highly recommends E rated or higher.
C rated seem to be the first to get cut down. (Southwest)
Usually on Coyote flats, Death Valley periminter, Arizona Peace trail.
But not "usually" Mojave, Southern Utah, Grand Canyon, New Mexico Gila.
Going to Niagra Rim trail for first time in a few weeks. Obstacle called "Sidewall Suiside", :eek: I'll prob take bypass but....
...the OEM GY M/T C rated are coming off Thurs, at 5k mi. Keeping spare for weight savings.
Just ordered 4x:
Toyo Tire Open Country R/T Trail
35 X12.50R17 LT 125Q E2 BSW
2 ply 10 ply rated vs C 6 ply rating.
Almost got R/T Pro which are all 3 ply 12 ply rated, but Trail is better on sand and lateral G's on pavement and well planted at 100mph+.
Ran KO2, Yokohama, Ridge Grappler and R/T trail before. All good.
But R/T trail E rated on my F150 is my absolute favorite so far.
Safety, Reliability, Performance, then phsy ops...
When I walk across the parking lot to the grocery store to get milk, diapers, feminine products, etc if I can look over my shoulder and say to myself dang that looks like it can kick some ass its a win...
Smocaine
DFW, TX
Cervelo Caledonia
I am still on C-range factory tires but I hope to run the Baja Boss AT in the 35x10 size and E range - narrow aspect ratios increases flexibility, making up for the stiffer sidewall.
Stiffness of higher-rated tires also varies wildly by manufacturer and even individual carcass. It's all a balancing act and there are a lot of screws to turn, each one affecting the others.
Pops
North of Seattle
2025 2-door, Sas, Mid Pkg.
may be ok but speed and a hole could be trouble plus I see rocks..
stock Sasquatch and raptor C tires are not to be trusted at speed on stuff like that…imho
Yes, agreed. I am the guy in the OEM Goodyears poking along less than 1/2 that speed on rocks like that.
I'm always alone and have no wish to be plugging or changing a tire on the trail. 🤞
Motovita
WA/AZ
25 Bronco
I'm trying to work out in my head how "narrow aspect ratios increase flexibility", help me out. I'm a tall narrow guy myself, mostly for increased traction in loose or slippery conditions.
Smocaine
DFW, TX
Cervelo Caledonia
For a given tire carcass diameter and pressure, a narrower aspect ratio simply has less material per radial slice of tire to resist deformation and experiences higher point pressure.
This negatively affects flotation but positively affects mechanical grip where it's available.
In simpler terms, and with many many caveats and yabbuts, they cut and wrap better where wide tires float and flat-grip better.
Motovita
WA/AZ
25 Bronco
Thanks, I've noticed the effect but hadn't considered the tread surface as resisting deformation, makes sense.
JaredH790
Rosharon, Texas
2022 Bronco
E-Load ... have not had a single flat since switching ... on A/T tires
Scedwin
'24 Badsquatch, '95 Range Rover Classic
Team D-load here. Toyo OC R/T Trail 315’s…triple sidewalls, super grippy offroad and on including rain and snow. Best of all worlds.
cparksjr
Clayton
Linden, MI
2021 Bronco Badlands, 2020 Ford F250 Tremor
Hey everyone, quick question/hot take for the off-road crowd:
Are you team C-load or team E-load?
If you’re mostly running light trucks or SUVs (like a Tacoma, Wrangler, or 4Runner) and spending time on the trails, C-load tires are usually the sweet spot. Here’s why:
  • Better Flex & Traction: C-load tires have a slightly softer sidewall, which lets them air down much better on rocks and mud for a bigger contact patch.
  • Smoother Ride: E-load tires are designed for heavy-duty towing (think 3/4-ton diesel trucks). Put them on a lighter rig, and you’ll feel every single bump on the pavement like you're riding in a lumber wagon.
  • Weight Savings: E-loads are heavy! That extra unsprung weight drags down your gas mileage, acceleration, and puts extra wear on your suspension.
Now, if you’re constantly dragging your rig over razor-sharp granite or carrying a heavy camper setup, the bulletproof sidewalls of an E-load might be worth the harsh ride. But for 90% of weekend warriors? C-load gives you all the off-road grip without destroying your daily commute.
Change my mind—what are you running on your rig right now? 👇
Fora Bronco, for sure C.
