Motovita
WA/AZ
25 Bronco
I suspect that some of the LRE converts were a kneejerk reaction to sidewall damage on stock Goodyears. My last set of Load Range C Goodyears was many years ago when I had a sidewall failure while driving on pavement.
BroncoStang
Thought I'd drop this in here...
I love his YT channel, so much tire information. I haven't seen this video until now but dang I wish I knew about that BFG discount before I bought my Coopers lol. Oh well.
I won't buy a GY tire. We used to have them at work and got sidewall punctures all the time. Never could wear out a set 'cause they kept being replaced one at a time.
I beat my factory Goodyears up, I should've taken a pic of them before the tire shop took them but they were scratched up, missing lugs, chunks taken out, lacerations; I was actually surprised despite all the abuse and their weak sidewall reputation that I didn't have any sidewall punctures and AZ knows how to take out sidewalls. They did only last me 25k miles though and I had them down to 4/32nd's already in addition to the forementioned damage. Lowest I took them was to 15psi.
jzweedyk
Moab, UT
2025 Lincoln Navigator
I have said this before, but if you look at all large 39" and up tires, they are all C range. All competition rock crawlers use C range and air down to 8 psi or lower. Think of a balloon. A thick aired up balloon would be really easy to prick with a needle, but a flexible soft balloon will allow the needle to push in and deflect the balloon and not puncture it. My 2 cents.
jzweedyk
Moab, UT
Also, don't use Goodyear tires. When they introduced the Kevlar ones, a lot of people switched. Two years later no one used them. Bfg is the best in my opinion.
Hummell
Adam
Charlotte, NC
I just walked out and filmed this. If you look close, you can see where the sidewalls take a lot of hits and abrasion. I do think it depends a lot on the terrain you're typically in. With sharp rocks, sticks, logs and stumps of the Appalachian Mountains, it just makes more sense for me to run an E.
For what it's worth, I'm a bit disappointed with even the BFG KM3 E rated lugs...several are ripped off in the rear.
Wyld2dr
2023 2 dr Bronco; 2016 Audi A7 tdi
Desert 37's, E load
Steve_In_29
St Johns, Arizona
2024 Heritage Limited, 2 Door, 1973 Bronco, 1999 Ranger, 2007 F350
For rock crawling C is the way to go. I use BFG tires and have never had a problem, even on sharp rocks. Just air down and they will conform over the rocks. I usually air down to 12 or so for rock crawling. Been wheeling for only 20 years, so what do I know?
That can vary.
Not all rock crawling is the same.
Crawling in Moab on smooth sand stone is a totally different thing than crawling over water smoothed boulders in an old river bed and both are different from crawling in Johnson Valley on jagged volcanic rock and sharp basalt.
Also the weather can have a big impact as wet tires slice MUCH easier than dry ones do.
I have 40 years of wheeling under my belt.
Steve_In_29
St Johns, Arizona
Those tires pretty much never have to last more than one season of racing. Many are replaced after each race.
Motovita
WA/AZ
25 Bronco
That can vary.
So what's your opinion on load range for a Bronco?
jzweedyk
Moab, UT
That can vary.
I agree that terrain can vary and some tires are better for certain areas. I would point out that not all trails in Moab are on smooth sand stone, there are a lot of sharp rocks. Also I have done quite a bit of wheeling in Colorado, and they don't call the Rocky Mountains that because they are smooth.
It would be interesting to survey the people who have punctured tires and ask what pressure they had in them at the time. I'll bet most are not aired down to 10 or 12 when it happens.
In my 20+ years of wheeling, I have broken almost everything possible on my Jeeps and Bronco, but have never punctured a tire (except on pavement, once with a nail, aired fully up). I always air down, even on most forest roads. Call it luck if you will. I am not an expert, but I have wheeled a lot, in a lot of states, and many times I have been surprised that my tires were not shredded by the terrain.
gbub
Gary
Costa Mesa CA
2002 Ford Ranger FX4, 1969 Fairlane Cobra, 1970 2800CS BMW, 1961 Austin Healey S
Please explain that? I don't understand how that works. Rubber does not act like sponge cake.
Steve_In_29
St Johns, Arizona
The tire doesn't soak up the water. The water just acts as a lubricant for the sharp pointy object.
Steve_In_29
St Johns, Arizona
It varies and a big part of the selection can be the exact tire you want. As the video pointed out in the case of the KO3s the manufacturer used stronger sidewall plies in the C to make up for losing a ply compared to the E rated one
