Driving without CV Axle Nut?
BigP'sGreenMachine
Jon
Austin, TX
2018 GMC Sierra
Dumb question but I was at a buddies shop today today putting on my lift and the axle shaft tread on my driver side got damaged. Can’t get the nut back on.
I realize I am likely going to need to replace if I can’t get it rethreaded, but am I safe to nurse this back to my house without that nut attached?
Can often clean the threads up with a file - assuming you probably pounded on it trying to get it out and damaged the first few and can't get the nut started.
Takes some patience, but it can be done.
kr_1315
Kevin
Houston, TX
F150, Tundra, Explorer, IS500, '23 Bronco 2DR
BigMeatsBronco
Allan
2021 FE 2 door
So much misinformation here... I've literally put 5K miles down without any CV axles, or axle nut. on older GM designs, they would come apart if the NUT was not there to hold things together. If there was gonna be a problem, the stress from the 41" tires would have found an issue...most Fords unit bearings are designed and built in a way that they are safe to drive without the NUT in place.
Ford Bronco Driving without CV Axle Nut? 20250217_080703
BroncoChallenger
2024 Bronco
If you were going to do this, I would consider just taking the whole CV shaft out, but depending on how the front pumpkin is built (I don't personally know) you could be inviting contaminates into the differential housing. I wouldn't drive it at all, if you needed to get it home I'd put it on a flatbed.
If you're careful you can fix the threads with a file, you may need to mess with them a bit to get a die to fit as shown above.
For future reference though, I'm guessing you took the nut off, then hit the end of the shaft with a hammer and boogered up the threads. Never do that. ALWAYS leave the nut on the shaft, preferably flush or a little proud of the end of the shaft, to break the shaft loose. Once the shaft is loose, remove the nut (if you did damage the threads, it will at least mostly straighten them back out), then remove the shaft.
BigP'sGreenMachine
BigP'sGreenMachine
Jon
Austin, TX
2018 GMC Sierra
Quick update, but first, thanks for all the feedback.
After a lot of patience, a bit of filing, and using the die, we are back up and running.
Just took me a few hours, and definitely learned some lessons on this one.
I’ll post a photo once a get my tires mounted and the alignment done.
Thanks again, everyone.
ScLeCo
Springfield
Charger Hellcat
Ford Bronco Driving without CV Axle Nut? 279121575_2783064088669394_1039176585845663738_n
