DIY Hard Top prep kit
CDawg297!
Cody
South Jordan, UT
2019 Ford Ranger
Found em. W721071-S450B. #7 shown here.
so if we have a soft top do we need to buy those #7 bolts? I assume we get 6 of them to attach the brackets?
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
I want to be able to run a dual top & haven't looked at pulling apart the existing hardware, so I'm not sure.
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
Sharing the updated comprehensive list of parts identified for the prep kit:
M2DZ-17A605-K - Dual Top Front Hose (under the hood, taps into the washer reservoir and connects to the M2DZ-17A605-D hose at the passenger firewall). Part number includes a set of both hoses, one attaching to the front washer lines and a second routing to the firewall for the rear washers
M2DZ-17A605-D - HOSE (runs from passenger firewall, down behind glove box, adjacent to wire harness running down passenger side and to cargo area hose M2DZ-17A605-F).
M2DZ-17A605-F - HOSE (connects to M2DZ-17A605-D and runs across the rear cargo area from passenger side to drivers side, connecting to M2DZ-17A605-G).
M2DZ-17A605-G - Lower Hose (quick disconnect hose that connects to hard top hoses, or next to the harness in the cargo panel when not used).
M2DZ-15A657-A - Wire Assembly (Connects to existing harness at rear of vehicle).
M2DZ-3F791-CB - Housing Assembly Steering Column (Front and Rear Washer Control, replaces existing, requires programming).
M2DZ-78245A26-B and M2DZ-78245A27-B - Hard Top Bracket Latch Mounts
TP50 Bolts (W721071-S450B) Quantity 6x - Secure Hard Top Bracket Latch Mounts
M2DZ-19980-C - HVAC Controls including rear defrost (heated mirrors, seats, steering wheel).
CDawg297!
Cody
South Jordan, UT
2019 Ford Ranger
so we do need to buy the bolts to secure the hard top brackets then?
CDawg297!
Cody
South Jordan, UT
2019 Ford Ranger
Are you asking about going from soft top to hard top or vice versa?
yes im talking about going from soft top to hard top. Do we need to buy those W721071-S450B bolts to secure the M2DZ-78245A26-B and M2DZ-78245A27-B - Hard Top Bracket Latch Mounts? or since I already have a soft top do I have those bolts already from the soft top equipment from factory?
flip
Phil
IN
www.ruxerparts.com
Fords
Are you pre prep package or post?
flip
Phil
IN
www.ruxerparts.com
Fords
W721070-S450B (M8X33) is for the cap to quarter and the two brackets, 12 total.
Ford Bronco DIY Hard Top prep kit 1686926283352
W721071-S450B (M8X24) is for the two brackets on the top of the cap that bolt to the roll bar.
Ford Bronco DIY Hard Top prep kit 1686926243889
CDawg297!
Cody
South Jordan, UT
2019 Ford Ranger
so I should get these ones? W721070-S450B (M8X33) is for the cap to quarter and the two brackets, 12 total.
CDawg297!
Cody
South Jordan, UT
2019 Ford Ranger
Front brackets should be there already. At this point it's just a choice of which of the above two bolts you wanted to use on the rear cap.
I didnt get the hardtop prep kit. So i dont have the hardtop brackets yet
flip
Phil
IN
www.ruxerparts.com
Fords
Sorry, misread. The shorter bolts should work in all locations as the longer seem like overkill.
CDawg297!
Cody
South Jordan, UT
2019 Ford Ranger
so the shorter bolts are W721071-S450B?
