CV Axel upgrade: RCV or Spicer or OEM
Darelle
New York State
2021 Ford Bromco Big Bend A51
I went RCV for a few reasons.
1. Was available at the time, Dana was not. Ended up being cheaper.
2. 300M can't find what Dana's are made from
3. Lifetime Warranty up to 40's- No warranty expressed on the Dana's that I can find.
I've been happy with them & their customer support
YMMV 🤠
Awesomeness, that is my next move this winter! RCVs. Thanks for the updates.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
It's either Spicer Differential and CV axles or stock. If you think upgrading CV axles will fix anything your going down the wrong path. CV are $400-500 a set and differential are $1700 pick your weakpoint.
Felix808
SRV CA
I've got a set for sale ;)
I would love to keep them, but just upgraded to the Dana UFDU & can't .
Felix808
SRV CA
Where they will help is more strength with the wheel cranked & better droop angles.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Yes they will hold together hammer down turned. We need to understand that the m210 is not built to handle that kind of punishment.
87-Z28
Andy
BMW
@Snacktime
Do we have data that shows they have better droop angles before binding? Or increased longevity at higher ride height angles, like >15 degrees?
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
@Snacktime
We need proof of better droop angles. RCVs should have a shorter life, they are not something I would run without locking hubs.
Felix808
SRV CA
How so?
Keeping them properly lubed it the key for longevity in any CV.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
How so?
Has to do with the metal and heat treat. Example in a 80 Series Landcruiser you will get 60-80k miles out of a RCV axle. That is a CV joint running full time with no angle. Broncos are running a constant angle so substantially more wear. Also people extend the life of the CVs by rotating them side to side.
Not knocking the product as much as explaining the differences. It's important to realize that the strength comes at a cost.
Az_Squatch_Bronco
Shawn
Tucson
Bronco Badlands w/ sasquatch pkg - Carbonized Grey
Just had my RCV axles installed...no noise or issues. Going to break them in on a trail this Sunday.
