- Andrew
- Mar 7, 2020
- 16
- 4,895
- 8,432
- North Carolina
- 2021 Ford Bronco
- Badlands
Well, since everyone should disconnect at every trailhead, itās a lot easier to push a button rather than manually disconnecting with a wrenchpersonally, I don't see myself needing the SBD simply because I won't rock crawl. I did want the manual and lux, so my choice forces me into a BL, but if I were going with an automatic, the WT would seem to be, by far, the most useful trim with the HOSS for my use. I suspect most Bronco's won't be on the rocks, so the disconnect is a party trick that is mostly worthless for the large majority of folks. If you don't plan on getting on the rocks, I think the choice is clear.
Having said that, HOSS 3.0 is pretty badass
