RCV AXLE MOVEMENT - PASSENGER SIDE.
Az_Squatch_Bronco
Shawn
Tucson
Bronco Badlands w/ sasquatch pkg - Carbonized Grey
For those of you with RCV axles, does your passenger side have this play in it?
This was taken with the stock axles, as we were trying to diagnose suspension noise on the drivers side, which as was resolved.
The tech at the shop who installed the axles thinks this is the same as the stock axle movement.
Az_Squatch_Bronco
Az_Squatch_Bronco
Shawn
Tucson
Nobody?
akturbo
Seattle Eastside
'21 Bronco, '24 2D HLE (wife's), 3500HD Chevy, Rav4Prime, Turbo Skidoo
Are you sure it's seated in the diff? I don't have RCVs but that looks like a big gap compared to stock. I'd pull that side apart and sure the axle is locked into the diff properly.
Az_Squatch_Bronco
Az_Squatch_Bronco
Shawn
Tucson
I had the shop swap back to the OEM axle, which has a much tighter fit. Not sure what RCV will say about it, the noise seems to have stopped but it may be to early to tell.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
I got the same problem with my brand new differential and brand new Ford CVs. I was thinking of dipping the CV shaft into a bucket of tacky #2 red grease and shoving it back in. It's the loose tolerance of the roller bearing just inside the seal.
