CPE Intercooler & Active Grille Shutter Removal
Tucker417
Garrett
Ozark
2023 Bronco Outer Banks
Just wrapped up installing the CPE Intercooler. Install took less than 30 minutes. The grille shutters are easily removed by pushing the tabs in on one side and sliding them out, leaving the motor intact and plugged in.
The CPE Intercooler is 3/4” taller than the OEM, much thicker, and has cast end tanks.
Fit and finish was top notch. If this is on your mod list, do it. 😎
Note: Removal of grille shutters is not needed for the install. I chose to do this for improved air flow to the Intercooler at all times. It seems like mine are closed 90% of the time.
Ford Bronco CPE Intercooler & Active Grille Shutter Removal IMG_3035
Ford Bronco CPE Intercooler & Active Grille Shutter Removal IMG_3036
Ford Bronco CPE Intercooler & Active Grille Shutter Removal IMG_3034
Ford Bronco CPE Intercooler & Active Grille Shutter Removal IMG_3037
Fordified1
Bob
Mid South Texas
I took my shutter assembly completely off when I installed my new bumper. Just unplugged and removed. Doesn’t throw any codes. I don’t know of any downside to this. Curious of educated opinions though.
Tucker417
Tucker417
Garrett
Ozark
I’ve read from others that it does not throw a check engine light but will send an error notification over to the ford pass app. Not 100% on this but that’s why I left it in tact. It also helps direct the air to the Intercooler.
WheresMyBronco
Los Angeles
2023 Badlands
From my understanding, the shutters:
  • Help your engine get up to temp faster
  • Keep your engine warm longer after you turn it off
  • Increase aerodynamics a bit at certain speeds
Don't think many people here care about aerodynamics, but the faster warm up time/longer cool down time are pretty nice. I think the longer cool down period also increases the engine life expectancy by preventing all the different components from cooling off too quickly or at different rates.
Tucker417
Tucker417
Garrett
Ozark
Keeping it warm longer after shutting it off? The shutters are only going to make a difference when the vehicle is in motion. Not sure how they relate to keeping the engine warm longer when it’s off. 🤷🏼‍♂️
Helping get to operating temp faster, I can see this yes as it is restricting airflow to the radiator while the shutters are closed.
Some have claimed an increase in mpg once removed. Myself like many others could care less yes lol.
Ducati1098
They also help keep condensation down. Older ecoboost F150's had issues with that so Ford blocked off a large part of the intercooler because it was causing misfires.
GI_Jo_Nathan
Jonathan
I have both my intercooler and radiator Grill shutters removed. No codes and nothing on fordpass.
Fordified1
Bob
Mid South Texas
To be clear. Condensation inside the intake enough to cause mis-fire? I assume this would be at low rpm part throttle?
Water injected into the intake tract used to be a thing for high performance turbo applications way back in the day, before everyone started using intercoolers, to help prevent detonation.
Ducati1098
Yes. With the F150 it was mid-higher rpm with high load, so more WOT.
Water injection is still a thing, but that’s a very fine mist, what was happening to the ecoboost was more than a mist lol
I haven’t seen any instances of the Bronco having a problem even with people removing the shutters, so I don’t really expect this would be an issue.
Fordified1
Bob
Mid South Texas
Maybe the water was pooling in the bottom of the intercooler until high flow situation siphoned it out fast enough to cause the mis-fire. I wonder how close anyone got to hydraulicing an engine because of that, or if it was even known why one blew the head off or bent a rod lol.
Ducati1098
Yeah I think that’s exactly what was happening. I’m not sure how much water was making it into the cylinders or if it would ever be enough to hydrolock the engine. I think it was probably just enough to cause a misfire, realistically it probably didn’t take too much
