Change Driveline Fluids Early!
jacknifetoaswan
JR
Charleston, SC
2016 Mustang GT/PP
With the nozzle I posted it's a piece of cake--even the plastic bottles are easy with the nozzle.
I'll grab it for the new drain and fill. I'm going to do a replacement diff cover at the same time to get the drain plug. Dumb that Ford didn't give a drain plug on the rear diff.
JR
23OBX2.7
AB Canada
2023 Bronco
JR
...or the 10R80...
jacknifetoaswan
JR
Charleston, SC
2016 Mustang GT/PP
...or the 10R80...
That's also going to be getting the PPE pan so I can do incremental fluid changes. So dumb.
I've been driving MTs for the last 15 years and it's just so easy to change the trans fluid. I forgot how insane it is to change an AT's fluid.
JR
23OBX2.7
AB Canada
2023 Bronco
JR
PPE pan is a must and on my list when hit 20K miles.
jtgensler
Jamison
Clarion, PA
2022 Bronco, 1996 Tacoma
Just have to find a good fill tube/dipstick up to the engine bay.
I'm so close to just buying the Ranger version & figuring out how to make it work.
23OBX2.7
AB Canada
2023 Bronco
Lots folks been looking for a long time....
CarbonSteel
CarbonSteel
Colorado Springs
2023 Carbonized Gray
jtgensler
Jamison
Clarion, PA
Agreed; I look into it quite a while ago and I could not see a way to make it work.
Given the ultra limited space near the fill port on the transmission, you will need one of the "candy cane" style tubes and a pressure tank to refill it as shown here:
https://www.bronco6g.com/forum/thre...ers-fluids-oil-changes-etc.86135/post-2134640
I did mine with the $11 pump from Harbor Freight.
https://www.harborfreight.com/gear-oil-and-fluid-pump-63588.html
but it would be awesome if Mike's Build Shop got their Bronco version of the transmission fill/dipstick to market.
Rockledge
Darryl
Fayetteville N.C.
2022 Race Red Sasquatch , 1951 Willy's M-38
I was changing the engine oil today ( 29846 miles - 4500 intervals ) and decided to change all fluids as its a very pleasant day out. I previously changed front-rear differentials and transfer at 2k, 10k and transmission at 20k. all were fairly clean.
23OBX2.7
AB Canada
2023 Bronco
Seems like the fist diff / tans case change interval is critical after that last for long time especially if 100% synthetic.
JL724
NY
Coming up on 30k miles and after reading this thread booked an appointment to have the front axle, rear axle and transfer case fluids changed (in addition to normal 30k mile oil change and air filter). Did not opt to do the automatic transmission at this point.
JL724
NY
Anyone have their automatic transmission fluid changed at a dealer? If so, what did they charge?
Lotus Dave
Isle of Kent, MD
2006 Lotus Elise
IIRC others had luck getting FP to replace these rust buckets:
Ford Bronco Change Driveline Fluids Early! B6
Anyone able to share details on getting theirs replaced? Given my luck, I'd get a FP replacement from the same bad batch...
I installed mine on 8-4-24 and am now debating on corrective action(s). I've seen others that had them custom painted to match body color, but mine's Oxford White... I kept the OE and could put it back on while this one gets redone.
Appreciate any insight.
23OBX2.7
AB Canada
2023 Bronco
It's a Patina adds value with rust bucket vibe!​
Just buy a new one and return this one as damaged part LOL.....Ford knows it's normal won't object haha.​
Fastmc25
Fastmc25
East Tennessee
24 Big Bend
i was quoted $360 to change transmission fluid at my local dealer
Didn’t do it though. Was just asking 😳😂
