- First Name
- Eric
- Joined
- Apr 11, 2024
- Threads
- 2
- Messages
- 113
- Reaction score
- 512
- Location
- Federal Way
- Vehicle(s)
- Bronco
- Your Bronco Model
- Wildtrak
- Thread starter
- #1
In 4WD, does the Bronco lock the center diff?
With 4A the transfer case is a differential, using a clutch to send variable power to the front differential. 4H or 4L doesn’t have a physical lock on the advanced transfer case, just a ball ramp that is fully engaging the clutch.Yes an no. In 4H or 4L the transfercase is 'locked'. In 4A 4wd engages and disengages as required automatically (with no differential) when needed. There is no true transfercase differential in any drive mode
Is there something going on or just curious?Thanks for the replies.
@sierrabronc, I haven’t seen any info or posts… the video you shared the damages was flat towing (maybe 4a) …This video shows the tcase being taken apart and shows the clutch. 4:46 and 15:58 are notable timestamps
I have seen threads on it pop up many times but never clicked as it wasn’t applicable to me.… the OP has his answer.
Do we need to do the flat tow procedure to configure /to put a Bronco in, if the Bronco is being towed off trail /recovery for any reason ( break down, battery, damage etc) ??
I’ve just always skipped over the idea that I needed it… but thinking we might need to…
Tks
Maybe that's like calling a copy machine a Xerox?I.m confused. I always called A differential the device on the axle assemblies that transfers the engine power from the drive shaft to the axles and the mechanical device that switches between 2 and 4wheel drive the transfer case connected to the trnsmission.
Differential allows for different rotations out of a splitter. Or…a differential in rotation. The Advanced transfer case in 4A, while the rear axle output is fixed, does allow for a differential on the front output. You can use 4A on dry pavement without issue. That wouldn’t possible without a differential…unless of course you only went straight.I.m confused. I always called A differential the device on the axle assemblies that transfers the engine power from the drive shaft to the axles and the mechanical device that switches between 2 and 4wheel drive the transfer case connected to the trnsmission.
I would say wikipedia has not kept up. Look at that history, ends in 1958. Not sure when (Porsche in the 959 of the 1980's comes to mind) exactly but eltro-mechanical systems (mostly wet clutch packs) have been doing differentiation for a while now.
