Center Display Screen Went Dark
CTU5000
2024 Bronco Outer Banks, 2024 BMW X3 M Sport
Purchased a new 2024 Outer Banks about two months ago. Today I drove about 30 minutes and shut down. When I re-started about 30 minutes later, the center display was dark... no logo, no back-up camera, nothing. Drove off and a minute or so later the display appeared to be sort of re-booting and came alive appearing normal again. Drove around and made several more stops and it operated normally.
Is this something that normally happens from time to time or is it indicative of a bigger problem?
Thanks!
BroncoChallenger
2024 Bronco
These big displays are basically small computers, and every now and then they do a 'self reboot' so to speak. Across Ram and Ford, we've had them take up to a couple minutes to fully come up and be functional, and there doesn't seem to be a rhyme or reason for it.
CTU5000
It's supposed to reboot if you hold down the power button and the seek forward button for 10 seconds. That didn't work for me, I had to take off the negative battery cable to get it to fully reboot.
Thanks for the info. In this case, I didn't do anything to initiate a reboot.
CTU5000
Thanks for the info. Guess for now I'll keep an eye on it and hope that it's just a "normal" system function. A little disconcerting, though.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Thanks!
Good afternoon. Would you please send over a private message with your VIN and dealer info so I can look into this concern regarding your display screen?
CTU5000
Dral97
Ford Bronco, Wrangler YJ, LJ, and 392, BMW 4 series
Happens to me once or twice a year.
The first time it freaked me out, but now I ignore it. *shrug*
userdude
Jared
Denton, TX
2023 2dr Badsquatch
Literally just happened to me yesterday, about the same circumstances/timing. Weirdly, my music continued to play from my iPhone.
Sunday Money
Thanks!
That happened to me once after I bought mine in 2021. Thankfully it hasn't happened again (knock on wood).
CTU5000
Yep, it is concerning. Ford responded and asked me to DM them the VIN and dealer info, so sent that to them. Curious to see what they have to say.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
It's not going to come to anything. They'll tell you to go to the dealer first. AFAICT, they do that so that the forum looks like Ford "cares" and is "helping" but it's not any help unless you've gone to the dealer and Ford decides to step in (which is rare). We're not even sure it's a real person or a chatbot.
TX-Dennis
Dennis
Southern LLano Estacado
Bronco, Lincoln
There’s a good chance it downloaded and applied an update to SYNC. This causes the system to reboot when you first start it sometimes. Check your Ford app to see if it shows a recent update.
Khakiman
Richmond KY
Tacoma
Same for me yesterday as well and sound still worked
BroncoChallenger
2024 Bronco
Yeah it's definitely something to keep an eye on, because if it happens frequently it could be a problem. But if it's only doing it once in a while it's likely normal, I've seen it happen across all brands with these big screens in them.
