HELP.. blue screen on center display when activating CarPlay
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
Southern Girl
1974 Bronco/2024 Wildtrak
Is there an SD card for the NAV that needs to be installed? Perhaps a reboot. Disconnect the battery negative terminal wait a minute and reattach.
That is not how you do it. There are a series of buttons to be pressed simultaneously according to Ford.
Ksjrb03
Tx
F250
As a sync owner through all the various iterations, you quickly learn what fuse to pull to reset the system. Sounds like there might be a button combination on this one to reboot, but pulling the fuse always works until the next reboot.
Compta38
Alabama
Ford Fusion
It came low on LCD fluid
Southern Girl
As in pull the fuse and put it back in to reset? I'm having issues with sync 4. Disappointing because I was SO SICK of the sync 1 I was using. The sync AI lady knew more about stuff in my old truck than the Bronco. :LOL:
Papa Smurf
Jax, FL
‘23 Bronco WT. ‘23 Maverick. Hybrid. '23 Rav4
An appearance/quality concern for the screen was identified. The issue does not impact the functionality of the screen.
Ksjrb03
Tx
F250
Correct. I don’t have my Bronco yet so I can’t tell you which fuse, but it’s always labeled Sync in the owners manual. Pulling the fuse and popping back on 15 seconds later forces a hard reset. I’m not sure if the button combo mentioned is a hard or soft reset but you can try that too.
I learned the fuse trick back in Sync 1, good times lol.
Southern Girl
Omg, I had no idea I could reset that sync AI lady. This new one can't seem to figure out which person I want to call. Easier to use android auto.
Bronc-O
Phoenix
2021 Lincoln Aviator
Is the a separate plug for the left screen?
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
I hear if you put it in some rice some lil Asian kid will come and fix it while you sleep.
stbanning
sean
Bonney Lake
f150 platinum, mazdaspeed miata
Bluetooth wireless carplay or wired? Or both? Maybe you have a bad iPhone cable for data. I know iPhone cords can be pretty temperamental not using the factory iPhone cord
