Caught my first flat ..
AzGrayHeritage
Keevan
Georgia
Azure Gray Heritage 24
Nasty screw picked up, more like bolt. Lucky I was close to home. No rim damage , lost air quick.
Then the fun began. Unpack jack, set up in my driveway. Not impressed with the jack, so def getting a new one. With that said , being super cautious I had it changed in under an hour.
Let's see if the plug it
Ford Bronco Caught my first flat .. PXL_20251221_205243392
Langwilliams
Langley
Cleveland Ohio
2023 Bronco big bend, 2014 Harley Street Glide
I hate the jacks supplied in cars. I don't carry a better one though. I picked up an aluminum 2.5 ton jack, got tired of the 110 pound steel one. I'm thinking about getting a bottle jack with the cradle to keep in the bronco.
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
Perhaps the camera's perspective is adding more slope than there is IRL. But next time, use some of that spare lumber to chock your wheels. The OEM jack is fine - not the best and certainly not the most stable base. For the rear wheels, use the rear axle not the rear trailing arms as a lift point.
BroncoChallenger
2024 Bronco
If I'm in my driveway, I'm grabbing the floor jack and stands. I can get them out quicker than I can the jack in the vehicle.
But if you're on the side of the road with nothing else, the included jack for most vehicles is adequate. It's not the best, but it does the job in a pinch.
I do prefer using a minimum 6-ton bottle jack though.
vbrad26
Vance
FL
VW's, an old Range Rover and now a Ford
I've used trunk jack twice and I actually thought it was ok.
Sure there are better options - if you're prepared.
But I've also used MUCH worse. You all ever used a VW/Audi jack?
They don't call those the widow-maker for nothing! I had one fold up on my roadside once...
shadowfax
Central Coast California
I’ll take the Bronco jack over this sketchy design of a 1970’s Volvo jack I had once upon a time.
Ford Bronco Caught my first flat .. IMG_1329
There’s always a sketchier jack!
BroncoChallenger
2024 Bronco
I dare say these are sketchier...
Ford Bronco Caught my first flat .. 1766423095144-
Ford Bronco Caught my first flat .. 1766423131875-vt
