Flat tires, now what?
CamBam
Cameron
Austin, TX
2022 Bronco Badlands Sasquatch Hardtop. Black
This is probably a simple question, but I now have two tires that have suffered basic flats due to screws in the road. I’ve plugged both successfully, but now I’m unsure what to do..
I off-road once a month or so, but haven’t with plugged tires, assuming that’s a bad idea.
I’d like to get a different tire model eventually since the OEM’s kick gravel up and cause paint chips. Is my only option to get five new tires now?
AKBronc49
Russ
Anchorage, Alaska
I've run on plugs for 5+ years without issues, unless you loose air I'd run'em...personally.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Take the tires/the rig to a tire shop for them to properly plug/patch the rubber? A proper grind down and vulcanizing should be as good as new, assuming the puncture locations/sizes/angles are all within repair
(I’m assuming you used a DIY roadside plug kit)
BlueBronco
DFW
As stated, plug'em and run'em. Or, if you have concerns, take them to a tire shop and have them patched. Definitely no need to go out and buy 5 new tires unless you just really want to spend $2500.
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
I’ve never had a plug wear out
