Catch can needed?
nabronco21
Nick
Pennsylvania
2021 ford bronco/2008 ford ranger
This is what my upr catch can captured in 600 miles on my 2.3 well worth the 250 bucks in my opinion. Also it's a quality product with factory style connectors no cutting and splicing. Almost 4 ounces.
Ford Bronco Catch can needed? 20220402_124215
BroncoAZ
Mitch
Wow, that seems like a lot. Isn’t the capacity of the UPR can only 5 oz capacity? I have one but haven’t installed it yet, but if it fills up that fast I’ll need to order their drain kit for it so it’s easier to do between oil changes.
filup01
‘21 F-150
I can’t say I’ve ever seen new engine oil look like that or have that color let alone used oil. Hmmmm
Also, if you’re catching nearly 3.5 oz every 600 miles or so, what’s the point of an oil change? With the amount you lose, you’d have to top off the oil in the engine pretty often and you’d be emptying nearly brand new oil every 5000 miles.
If that really is your oil from your new Bronco and not one that’s 40 years old and sitting in the rain with the hood off, I’d recommend sending that oil off for analysis. It just looks fake to me, that’s all.
Saltlife4shore
Anthony
New Jersey
2021 Big Bend
It's not just oil. It can also contain water vapor, weather makes a difference, and also could be some gas in there as well.
nabronco21
Nick
Pennsylvania
I was surprised when I opened it wouldn't have thought there was that much in there. But yeah it's probably 5oz or so.
nabronco21
Nick
Pennsylvania
Yeah it has a fuel smell for sure. Upr states there will be more in the colder months, I'm in western pa so just coming out of the winter months.
nabronco21
Nick
Pennsylvania
Not fake took it right out of the catch can and into the measuring cup. It is installed on my new bronco.
Skott
Missouri
2022 Bronco
Have we concluded that either a catch can or an AOS is at all beneficial on the 2.7L V6?
Thanks.
BrentC
Brent
Calgary, AB
I’ve had a catch can on my 2013 Focus ST since new, one on my 2.7 in my 2019 F150, and I installed one on my 2.3l. The winter emulsion collected is mainly condensed water, and fuel from the cold start. The oil blow by is the gunk at the bottom and is not that big a quantity. In the summer you’ll see what I mean.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I’ve noticed a big difference in my UPR over the past few months. Should I be dumping that orange milky stuff in winter or is the main concern the thick black stuff that’s been accumulating since it’s warmed up? I checked it today and it was a cold morning and it was solid at cold temps. Once I warmed it up a bit to dump it - it was pretty sludgy.
BrentC
Brent
Calgary, AB
UPR recommends you dump it weekly or even daily during the cold months. I installed the drain line option with the drain valve where I can easily reach it. I find the need to drain it corresponds to how much use - sometimes i’ll go 2 weeks in the winter before draining. I park in a heated garage, though - you can risk damage to the catch can’s internals letting it freeze.
BigMeatsBronco
Allan
2021 FE 2 door
Thanks.
People who understand the injection system on the intake ports on the 2.7, also understand its not needed for the 2.7...those that don't understand still think it's needed or beneficial. Earlier f-150 versions of the 2.7 did not have the dual fuel injector technology installed and they DO benefit from the can.
DogHauler
Chuck
New England
2022 Badlands Sasquatch 4dr 2023 Black Diamond 2dr
False, would you please stop repeating this misinformation.
redone17
Cold Spring, NY
Yeah, I can see that drain line coming in handy. Might have to order one for next season.
I just switched to Motul oil after 10k with Motorcraft (changed at 2500 and 5000). Interested to see how it performs.
