Catch Can or Air/Oil Separator question
murrman
Sean
Toledo, OH
2024 2 Door Black Diamond
I've been looking into possible mods to do, and an oil catch can keeps popping up as one that's recommended. After trying to do some research, it seems like there are various third-party options as well as a Ford Performance option. Where I start to get confused, however, is it seems like the Ford Performance option installs on a completely different part of the engine compared to the others. I don't know nearly enough about how these work to try and understand if one is better than the other. Would love some insight from anyone who knows more than I do about this.
murrman
murrman
Sean
Toledo, OH
I’ve done that, which is how I learned what I mentioned in my post. Unfortunately, I haven’t been able to find a clear explanation as to why the Ford one is so different. Hence my original post.
Wilbur's son
Hesston, KS
2001 Ranger 4x4
2 sides to the system. In a post, in a thread somewhere, is an illustration showing that Ford has a separator on the side of the block that vents back into the oil pan. The FP Air/Oil Separator is on the other side of the system. From the valve cover back to the airflow pre-turbo.
murrman
murrman
Sean
Toledo, OH
Thanks. Is there any consensus as to which approach is better?
Wilbur's son
Hesston, KS
2001 Ranger 4x4
There are many guys that bypassed the "vent to oil pan" and used either UPR or Mishimoto catch cans instead with good results. Caught significant residues. The FP AOS system I believe guys have had mixed results. Personally, I have the FP system and have caught vapor residues. I feel my choice is worth it. Read all the threads. Good explanations. Opinions vary.
Tucker417
Garrett
Ozark
2023 Bronco Outer Banks
FWIW, I have the Ford Performance and the J&L oil separator. Both work as advertised. The J&L always has a puddle in the bottom of the can every time I change the oil at the 5k mark. In the colder months you definitely get more than in the summer.
The Ford Performance one also works, it just does not accumulate near as much as the J&L does. Easy to open up, clean, and re assemble though.
