IAG air/oil separator
5GENIDN
Joe
Idaho
that's hardly evidence that "Ford recognized it was inadequate". All that is, is proof that Ford recognized people will buy anything if it says "Ford Performance" on it.
Very reasonable point.
5GENIDN
Joe
Idaho
The ford performance one didn't seem to catch anything yet. I've only had it about a month. If you put a catch can on the PCV line it will catch oil the stock system mises. I would say the stock system lets an adequate amount of oil into the intake manifold but it could be worthwhile to stop some of it from getting past if you're into that sort of thing.
I like stopping it because it is not suppose to be there and I do not like it getting burnt onto the back side of my valves. There is no positive side to having that oil vapor in that location.
e.alleg
Everglades
Ed
Alfred, NY
www.alfredauto.com
2024 Bronco, 21 F150 HD, 23 F550 Rollback
Everglades
I’m curious as to why this would be necessary. Shouldn’t the vehicle be equipped with one already? Does anyone have an air/oil separator installed and does it boost performance in anyway or is it an overpriced do nothing device?
https://iagoffroad.com/iag-air-oil-...FkWEPHel47cPYQXK7Ke3Dh95Ko6MGIjxoCcMIQAvD_BwE
I'm am ASE master technician since 1993. The bottom line is this item in not necessary for most drivers, and not necessary for lower performance engines. Turbocharged engines that constantly run at high rpm could utilize a separator, but I don't think there's ever been a failure on a Bronco due to the "problem" this solves. I don't believe it hurts anything, and most likely improves on the factory design, but what you are actually gaining from it is unclear. Not hating on the companies that produce these things, but if Ford could reduce warranty claims by using this part you can bet it would be on every engine they sell.
5GENIDN
Joe
Idaho
My argument is that it will NOT reduce warranty claims.... I believe it will not have any significant effects until the motor is well over 100K.... It is at that point build up on the valves starts to become an issue.... Some may not see it until 200K... others sooner. But for me, I intend to keep this vehicle until I can no longer drive.... So it makes sense to me.
CalvinT
Calvin
Phoenix, AZ
Get one if it would make you feel good. I like IAG, I have their steps. I installed them before my Bronco left the dealership. But I can't see why one of these is needed for a stock engine. You can bet if oil in the intake was a problem EPA would require this on new vehicles.
B22-2023
Houston
I’m putting my IAG in this week to replace my (soon for sale) dirty side J&L - it gets oil in it it and it’s PITA extra maintenance item for me, although they put a drain port on it and I could easily rig something up.
The other advantage of the IAG for me will be access: getting away from the OEM PCV fitting setup -talk about a PITA esp. using picks or a special tool to open up the line, with the Injen and I guess probably other charge pipe setups. Driver side PCV accessible up top and and not in the well, I’ll take it. I have enough trouble servicing the charge pipe t-clamps down on that side.
AdamF@IAG
Adam
Maryland
iagoffroad.com
'22 Bronco Raptor, '21 Bronco 2 and 4 door, '24 Ranger Raptor
Have you received a CARB EO yet?
Thanks
No, that process takes a year or 2 after submission. We are still waiting on our EO for the Subaru AOS.
Ninjak
Miami
Are you guys having any sales? Would love to set up AOS on the BRaptor. The one I help you guys test for the 2.7 was a great product.
IAG Off-Road
JJ
Westminster, MD
www.iagperformance.com
cgskipper
Justin
Ada, MI
2024 Ford Bronco 4dr Badlands
I'm thinking of getting the IAG AOS for my 2024 with the 2.7. I have about 23K miles so far. Do I need to do anything after installation to "clean up" the time prior to installation?
5GENIDN
Joe
Idaho
My recommendation would be just use good quality top tier gas... Unless you want to tear the heads apart...
Personally I would probably not go that far though... I would just use good gas... I am not big on the "additives" though.
