Cargo Area Light Advice
WJC
The North Coast
1976 Triumph Bonneville, 2003 BMW R1150R
I just bought a new 2024 Outer Banks and the cargo area seems poorly lit.
I've found several suppliers of, "Multi Angle Interior LED Lights" which replace the OEM light.
They all look almost identical and prices range from around $115 to just under $50 on eBay.
These are the ones that have several rows of leds and fit over the rear roof bar, plug in where the OEM light was, and attach with 3M tape.
I'm wondering if anyone has installed any of these and can recommend any or all.
Thanks in advance.
I bought the AIGMUX one on a lark when they were running a sale. Pretty underwhelming. It is brighter, but it's not really brighter enough to be worth the money.
I'd recommend just sticking some battery powered lamps or some 12V ones and plug em into the power point back there and turning them on when you need em.
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
I went through the hassle of installing some hardwired lights for the cargo area and would not recommend going this route. One of the main limiting factors of this is if you tie it to nine the cigarette lighter, it times out, or is not available if the door has been open for a while.
It's become so problematic that I've gone back to looking for some magnetic, battery powered or rechargeable LEDs
cr117
PNW
Bronco, EV6
A simple rechargeable light does the trick. Plus, you can detach it and use it elsewhere when needed.
Ford Bronco Cargo Area Light Advice IMG_1127
Headsong
I just went with easy and cheap @Mabett replacement. Only hard part is getting old one off!
23OBX2.7
AB Canada
2023 Bronco
Ford has a Mustang LED trunk light accessory that's about 2' long and very bright that is probably plug and play I should have taken it from my Mustang before sale. I will order another can always return if doesn't fit or can't be retrofit. Two way tape can just stick it to side panel or bar.
helifino16
Ron
Mount Sinai, NY (Long Island)
This was pretty easy to install and leaves you with the capability of controlling it from the driver's seat as well as coming on when the doors are opened.
Mabett
Mabett
China
www.facebook.com
Bronco Black Diamond
Thanks in advance.
I could offer you a discount if you want to try ours.
CalvinT
Calvin
Phoenix, AZ
WJC
The North Coast
Hello Mabett,
I've tried replying and dm'ing and received no replies from you.
Maybe I'm doing something wrong.
Please let me know the best way to reach you.
Thanks, Bill
BeachTiger
South Carolina
2019 Ford F150, 2022 Bronco Badlands
This a really good magnetic light from Harbor Freight that I've used. They have a 2100 lumen version for twice the price if you really need it.
Ford Bronco Cargo Area Light Advice Screenshot_20250913-122956
WJC
The North Coast
Hi Beach Tiger,
Thanks for the suggestion.
I actually have the Snap-on version of this light.
I never thought of using it in the Bronco.
It should work fine until I hear back ffrom Mabett.
