Cargo Area Light Advice
OracleLights
New Orleans, LA
www.oraclelights.com
If you’re still looking for a more integrated option, we do offer an LED Cargo Light Module specifically for the Bronco. It replaces the factory rear wiper motor cover and adds dual 5000K white LEDs to illuminate both the cargo area and the space directly behind the vehicle. It uses the factory rear 12V accessory socket, so installation is plug-and-play with no cutting or splicing required. There’s also a flush-mounted on/off switch built into the panel. It fits 2021-2025 Broncos and installation is typically around 30 minutes.
More info here: https://www.oraclelights.com/products/ford-bronco-led-cargo-light-module
Definitely another option if you’re trying to improve the factory cargo lighting without adding separate battery-powered lights or running a bunch of new wiring.
Ford Bronco Cargo Area Light Advice IMG_63152_90c2efeb-3b2a-4c2a-b01d-f50fab06c02a_700x700
BeachTiger
Joe
South Carolina
2019 Ford F150, 2022 Bronco Badlands
Are you just sticking it to one of the roll bars? does that flood the whole cargo area?
Yes. I just stick it to a rollbar. The light tilts if it's not obvious from the photo, and I find it plenty bright.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
I just bought a new 2024 Outer Banks and the cargo area seems poorly lit.
I've found several suppliers of, "Multi Angle Interior LED Lights" which replace the OEM light.
They all look almost identical and prices range from around $115 to just under $50 on eBay.
These are the ones that have several rows of leds and fit over the rear roof bar, plug in where the OEM light was, and attach with 3M tape.
I'm wondering if anyone has installed any of these and can recommend any or all.
Thanks in advance.
We sell a bunch of the Kingpin lights for the rear. They are available as a white light only OR a dual-color white/red light (F-Series)
The 12" work great back there and you can connect it to a cig plug and plug it into the cig plug if you wanted
https://www.4x4truckleds.com/kingpin/
