Car wash etiquette please
Why? Those things are fully lubed up with soap solution - crazy amounts actually. And the bristles are soft. I've never had an issue using them on my Bronco 'Scratches' or my 2013 Miata "Stripey".
Often loaded with mud or road dirt from whomever came ahead of you.
Once had one that had a big blob of tar and gravel stuck in the bristles and scratched the crap out of some aluminum rims before I noticed.
Desmolicious
SoCal
2025 Bronco HE, MX5
So check it before using it? I don't mean to be argumentative, just from my usage experiences. The ones I use have crazy amounts of soap coming out of them.
But I appreciate the reminder to do that!
Phoenix Justice
Oregon
Multiple
That sign on the wall should be all you need to know, keep on moving, brush in or out.
heavyD
Calgary, Alberta
2025 Badlands 2-Door
In general you don't use any sort of brush on paint, period. It's why most modern wash mitts are microfiber. Today's water based paints are soft and delicate and I have a hard time believing your clear coat doesn't have micro scratches and swirls from using car wash brushes on paint.
WheresMyBronco
Los Angeles
2023 Badlands
Shine a flashlight or let the sun hit your paint and you'll probably notice a ton of swirl marks. Might not be as noticeable on some colors like your Robin Blue but they'll be there
freebob
bob
michigan
2022 bronco
Car wash etiquette? I thought it was how much do you tip the guy .For washing the bronco inside and out...lol
Scott M
PNW
'23 Bronco Black Diamond, '99 BMW M3, '88 BMW 325i
Lots to unpack here :D
First of all, no matter which way the brush is facing, I assume it is filthy and filled with rocks and never use it on the paint.
Vevor. I also like it for washing exterior windows on my house, and can't wait to use it on my camper because that's a real pain to dry!
Which model did you buy? This one?
Ford Bronco Car wash etiquette please 1776971770557-c5
1894 toilet paper holder patent…this is the correct way 👍🏻
That's the correct way for that specific design which has the small secondary under roller. That diagram doesn't apply to modern holders.
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
I’m thinking of doing this too. What kind did you go with?
Oh, and I also have quick releases on everything and a shut off valve on my hose, so I can go from pressure washer / foam cannon to regular hose nozzle to deionized easily without turning off the hose at the bib. And, you'll need to hoses to use the de-ionizer, I went and bought a 25' hose that is dedicated to the deionized water ;)
CalvinT
Calvin
Phoenix, AZ
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
This is the only way. It is for hygienic/sanitary reasons. In the event your fingers come into contact with :poop: , the toilet paper on the roll will come into contact with your fingers when reaching for the next section of paper. If it is positioned the other way, it is likely that your :poop: fingers will come into contact with the wall behind the toilet paper.
