Capable bumper D-ring paint
armand0609
Armando
Minnesota
2022 Bronco Badlands, 2020 Nissan Armada
It looks really close to me. I wonder if you can order just those.
From what I have seen, it should be an easy swap. I found the diagram in one of the dealerships parts catalogs. Looks like it is Item 20. You will need to order left and right. However, personally I would wait until the parts are more common. The parts are $70 each and it seems a bit pricey.
I would pay that much for a machined one, but for a casting is too much.
https://www.oempartsforyourford.com.../Front-bumper-Bumper--components/ML21008.html
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
The capable bumper and the modular bumper share the same skid plates. So based on what this guy did, I do not think it will be an easy bolt-on. The guy had to cut some brackets from the frame (n)
One of my projects in the next few weeks will be to design a custom bracket for a Warn winch that can be mounted hopefully without removing brackets. It will also need a custom skid plate. But it will be huge if I can avoid having to cut parts from the frame.
Following to see how the project turns out.
armand0609
Armando
Minnesota
awesome so does it look like you could paint them without even taking anything off? Just mask around the whole thing?
Yes!
In fact I could not wait and just got it done. I was not that careful masking around it and got a bit of flash on the inside bracket of the bumper. But when I snap the covers back on, it will not be visible. At the end, I decided to go with silver paint, like the Bronco concept. In black they go completely unoticed, but in silver they really pop and they match the Bronco letters.
https://fbn-prod.s3-us-west-2.amazonaws.com/uploads/2021/08/Capable-header.jpg
Ford Bronco Capable bumper D-ring paint PXL_20220201_014502531
Ford Bronco Capable bumper D-ring paint PXL_20220201_015156054
Tarheel_Wes
Wesley
FJ
Yes!
looks good
I had not considered painting the mount brackets as well, just the rings. But that looks good.
Tortuga353
Laguna Beach, FL
Nice! That looks great. Think I’ll do mine in badlands orange or white for now.
Might get mounts machined locally.
Tarheel_Wes
Wesley
FJ
Tarheel_Wes
Wesley
FJ
What do you guys think would look good on the Eruption Green (for painting the D-rings)?
Eruption Green
White
Satin Silver
Chrome
Tarheel_Wes
Wesley
FJ
I think the original bronco presented with matching grille color (gray) looks great
Oh, meaning those original photos released when the Bronco was announced? My BD grill is obviously black...but, yea, I should throw that consideration in there too...a color to match the MIC gray....
broncosor
broncosor
Paint dried up!
Put the covers back on. I like how it turned out.
Do you need to scratch it with sand paper before applying paint?
Never done that before so just wondering what's the best process.
armand0609
Armando
Minnesota
I cleaned the surface with alcohol. But the surface was already pretty rough (material is a casting). So far it seems the paint is sticking on. But rubbing it with a Scotch Brite to improve adhesion will not hurt.
Tarheel_Wes
Wesley
FJ
What kind of paint did you use?
did you use a primer first and/or a clear coat after?
armand0609
Armando
Minnesota
I used Duplicolor Engine Enamel paint. I just cleaned the shackles and base prior to painting. The surface is pretty rough from factory, so I figured the paint should not have problems sticking.
I could probably have done a better job painting, but I see it as a short term finish. If you really want a good durable finish the best way would be to remove the base and shackle and get them powder coated.
But mine so far are holding up.
Tarheel_Wes
Wesley
FJ
Cool thanks
I finally took delivery. I was noticing on the shackle itself the hinge has a little tiny rubber grommet on each side. Wondering if paint or powder coating would mess that up in any way.
