Bronco seats uncomfortable?
Fordified1
Bob
Mid South Texas
ā€˜15 Mustang ecoboost, 4wd Excursion, ā€˜69 Mach 1
Nah, I'm on your side. I was trolling him^. Just like in all the other seat threads, I get tired of the people telling us that there's nothing wrong with the Bronco seats, and that there must be something wrong with us.
It turns out that people come in all different shapes and sizes, and what works for one doesn't necessarily work for everyone.
I haven't had the time to play around with seat jackers yet, but it seems like it might be a viable solution…
People that make fun of folks who have back pain don’t understand. There oftentimes is no cure and if a seat doesn’t fit you well and causes extra trips to a chiropractor then we look for a solution.
Headsong
I generally love them. But there's something odd about the right side bolster that's under your accelerator thigh that causes pain in 20-30 min...on the road no biggie, cruise is on. But around town, it's bad. NO idea what do. Have tried shifting positions, etc...to no avail.
DUSTYcazOREGON
Craig
I have a 2023 Bronco 4 door outer banks edition. The driver seat is very uncomfortable, doesn't matter what adjustments are made. I'm wonder if other people have had the same issue and what they did to solve it.
I have had 4-5 F150's and found those seats very comfortable. My Bronco seats are just as good and I am happy with them.
RobWTX
This reminds me of my dad's 1976 Ford Econoline van and the crap seats they had. He put some washers under the front bolts to tilt it back a little, which helped a lot.
USMCAg
Brazos County, Texas
2016 F-150
Gene Dios
Atlanta
Seat jackers just raise it slightly, correct? How is that different from the height adjustment handle that's already on the seat?
Fordified1
Bob
Mid South Texas
To raise just the front of the seat bottom. To change the angle.
Lucas
Lucas
Connecticut, USA
Ford Bronco
I have a 2023 OBX with high package (leather electric adjustable seats) and the driver seat caused me significant lower back pain for at least the first month, no matter how I adjusted the seat, lumbar, etc. But, it has slowly improved overtime (or my back has just adapted). I’ve driven for nearly 20 years and have never had lower back issues in a vehicle, so the Bronco seats were definitely designed poorly.
Ksjrb03
Tx
F250
Most uncomfortable seats I’ve ever owned, by far. Only here to add that so you don’t feel you’re the only one. I’ll probably try these seat jackers others are talking about. Can’t make it any worse.
Moto26
Tucson AZ
The OEM height adjuster tends to raise the rear of the seat more than the front as you go up. Seat jackers go under the forward seat mount, rocking the seat base back, which gives your thighs a little more support.
I’ve had Recaro sport seats in a previous truck, and there were adjustable mounting holes in the seat bracket, and you could definitely tell the difference when you changed it.
Since the Bronco is my wife’s primary vehicle, I don’t get to fiddle around with it as much as I’d like, and I always forget about the seats until it’s time for a road trip, and then it’s ā€œOh yeah, these seats! Ughā€¦ā€
Last time, I asked her if I could experiment with jacking the seat up, and she said go for it. But I just haven’t had time yet…
So I'm in the same boat as a lot of folks (on this thread and others) - seats are ok, but after a while they do start to bother my back a bit. I can't quite put my finger on why though.
I do tend to slide over towards the right, probably because I leave my hand on the shifter most of the time, and that puts my back not squarely center in the seat. When I realize it, I slide back to center and that helps. But yeah, after 2-3 hours my back just gets stiff.
I installed some washers yesterday - tipped the front end up about 1/2" or so. Will see how it does. Just sitting in it for a minute to make sure I had everything tight felt ok, but then again, the seat at stock level felt ok too. I'll have to put some hours in the seat.
Baja Bronco
2Sun AZ
The seat jackers have me interested, but that’s a lot of money for basically nothing. I might try the washer trick.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Here's a secret that @Tricky Mike doesn't want you to know, but makes your seats (apparently) much more comfortable. Those industry fat cats don't want this to be shared though, so keep this tid bit of information to yourself.
Ford Bronco Bronco seats uncomfortable? s-l1600
XirallicBolts
Xira
Midwest, USA
2016 Flex EcoBoost, 2022 Silverado LT
My f150 has the massaging seats ..wish my bronco had em.
Add them -- I did in my Flex ;) If the Bronco were mine, I'd have done the retrofit already.
Sometimes it would help if people posted their height/build when discussing seat comfort. I'm 5 10, average build, and the Bronco feels fine to me. Better than my 22 Silverado, little worse than my 16 Flex.
