Bronco seats uncomfortable?
67BroncoG1
Ron
CA
'22 2D Squatch, '67 Bronco, '24 Grenadier -ordered
I find the seats acceptable but not great but keep in mind that my daily driver in LA is a fullsize Range Rover and my daily driver in Washington is a Raptor. My biggest complaint is that the seat bottom isn't long enough for proper support. Another inch and a half would make a big difference.
A907Chick
Kelly
Anchorage, Alaska
'21 Ford Bronco Wildtrax Area 51
I would look in to working up to more lumbar support. There is a reason why it's in cars and is a big part of ergonomics. May end up helping you in the long run even if it's a little uncomfortable to start.
Funny you mentioned that. My husband loves lumbar support, I do not. I sat in the Bronco for nearly a week with it set on his lumbar preference before I found the wheel to dial it down. LOL. I kept feeling around for it and couldn't find it. Meanwhile, I was just sitting up away from the seat because it was so uncomfortable. I have a messed up lower back so the lumbar aggrevates it. It is much more comfortable set on the lowest setting but I do find the passenger seat has less lumbar.
My old vehicle had power seats with memory. The only adjustments that didn't reset with the memory was the lumbar, so everytime my husband drove, I would have to zero out the lumbar.
ChompSticks
ChompSticks
Cumming, GA
'02 E55 wagon, '98 Suzuki X-90, '96 Town Car
After a 500 mile road trip. I find long term seat comfort isn't there for either me or my partner. The MGV seats have an amazing feel to them, but the comfort is just off after 2hrs of driving. Might have to dial in seat adjustments a little more.
cricex
Charles
Austin, Texas
2.7L CG Badlands Sasquatch
Drove 900 miles to Colorado and found the MGV seats to be very comfortable.
Arnold1
Los Angeles
Maverick
So I received my Big Bend standard package manual transmission Bronco two days ago, and the seats are so uncomfortable that I am having intense back pain. I’m wondering if this is the case for anyone else. The lumbar seems to sit lower than my Xterra and is not height adjustable. I’m used to driving on truck chassis and a stick as I had an Xterra (manual) forever so it’s not that. But these seats just feel wrong no matter how I adjust them. Everything else about the bronco is great. Just wondering if anyone else is having this experience or has thoughts.
I just got my Cloth seat Outer Banks and I have the same issues. I tried everything to find a decent seat position and so far haven't found it. My wife feels the same way. No matter what position we choose, the seat is super uncomfortable. I am regretting not ordered the leather seats, seems that you can adjust those in more ways. It is crazy that the seats of the much cheaper Maverick are so much better. I took a 13 hours road trip with the Maverick and no issues at all, seats were super comfy.
I am still hoping to find a proper position with the Bronco seats.
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
I actually find the seats quite comfortable. When I bought the Bronco I drove it home for about 12 hours and really found them quite nice. Sorry to hear you're not having the same experience. Have you tried adjusting the lumbar support?
Arnold1
Los Angeles
Maverick
I have tried everything, but no luck so far. Do you have the cloth seats?
Bt_ostate
Oklahoma/Colorado
2021 Ranger Tremor 2021 Bronco 4-Door FE
I have the power seats in leather in mine and have found them to be far more comfortable than seats in many other vehicles. I'm very happy with them.
MillerAndCheeto
Robin
Calgary, AB
Yah, I have the cloth seats. That really stinks you don't like them.
squid1
Maine
Xterra
I went from an Xterra to a Big Bend as well. I was very uncomfortable for about the first month driving it. It took a lot of adjustment to the height and distance to the steering wheel/pedals to finally find the sweet spot for me. Now I find the seats comfortable and now longer have any pain associated with the seat. Through all the seat adjustment I did, overall I think was my body that finally just adjusted to the new seat. Hopefully the same will happen for you.
JT58Bronc
JT
Fl
2022 Bronco, 1987 Chevy Squarebody 4 X 4
Interesting post. All vehicles are different and it seems people at the different ends of the spectrum (shorter, taller, long legs, arms etc.) sometimes have issues. I have short torso and very long legs (6'1, 34" inseam) and some vehicles I have had problems- knee pain, etc. as some of you have described- so I know!
My problem has typically been not being able to get the seat back far enough- or the more common problem is the seat goes back enough but then I can't reach the steering wheel comfortably- no or not enough telescoping. I have done some extreme things on past vehicles- move the steering wheel out- very custom work- machined spacers and fabricated custom rings, etc. I have also made special brackets, spacers, to raise the seats. My recent 2019 Silverado LD had no telescoping steering and even though the seats were comfortable when I got the seat back I could not reach the wheel comfortably. So I moved the seat closer and had to twist my knee to reach the gas pedal and brakes. I had terrible knee pain. My solution was to raise the front and rear of the seats at different heights- custom spacers and brackets- trial and error for when I was comfortable. It was trial and error and a lot of work but in the end it was successful.
My point is try different things- pedal spacers- telescope the steering wheel all the way in, seat back straighter, etc. for the shorter folks. The opposite or seat spacers front and or rear, even different heights for the taller folks or folks with long legs like me. You can raise (or lower) the seats with custom brackets- it's not hat hard to do.
As for the Bronco specifically I find my base seats pretty comfortable. I have the steering wheel telescoped all the way out though and the seat raised pretty far up with the lifting mechanism- so it just makes it. The bottom cushions are a little short for me but I still find the seats overall comfy.
Jim Walter
Athens Ga
2015 JKU
Enjoying the MGV seats in my BL. Think they are very comfortable.
pony2bronco
Ryan
Maryland
2DR FE
I love the manual leather seats (2dr), can sit for long trips no problem. That said, after I have it in the shop and they adjust the seats it takes me about 1-2 weeks of daily driving to really dial it back in.
