Broken Bronco seen on Facebook
BAUS67
redneck
Central PA
More than one now! Got an inny instead of an outie though.
Just wait till all those "self" squatchers start wheeling hard and start having front axle problems. :ROFLMAO:
618TRVLWILD
Ashley
Southern Illinois
Big Bend Sasquatch 2D
Yeah I made a PSA today just for that in my FB group. Lucky #epicoorange is in the group to lend some wisdom from experience. 🙌🏻🤠
Shinoko
Asheville, NC
Badlands Sasquatch
Does Sasquatch come with upgraded axles and tie rods? Is there a reason that would be an issue for "self" setup Sasquatch models vs factory configured.
So far I've seen 3 of these, all with different wheels/tires than stock. Any idea what tire sizes were involved? At least one here was on 37s, I can't tell with either of these if there was a left or larger tires.
BAUS67
redneck
Central PA
Squatch has a nodular iron case and is 210 MM. The non-squatch is aluminum case and is 190 MM.
So yes the squatch has a stronger axle. Tie rods are the same.
The bigger the tire the stronger axle you will need, in theory. If you are light wheeling or going to the mall you can get away with it but if plan to use it and use it hard then troubles will be on the horizon.
One other consideration is the weight of the wheel and tire combo. This is can cause premature problems as well.
kodiakisland
Arkansas
So far axle doesn’t seem to be the issue, so self squatch or real squatch, it seems 37s and factory tie rods MAY be an issue.
Would like more info to see what the real issue is.
BAUS67
redneck
Central PA
I haven't seen axle problems yet either and for the most part you won't until people start "hard" wheeling with their "selfie" and I don't see them breaking it either. It will just "wear out" faster.
Bigger, heavier tires have a larger load on the axle assembly. Aluminum will "defect" more than cast iron when put under heavy loads. This "defection" may not break something but it will wear on it and cause it to fail before the stronger one will.
618TRVLWILD
Ashley
Southern Illinois
Are these overly aggressive off roaders, or are these overly fragile tie rods?
#epicorange pretty aggressive off roader. His first split was out in the rubicon. I also believe fragile rods. 2nd spilt was in Moab. He also runs 37s.
AK SNO RIDER
Ty
Alaska
Like I said in the other thread, this is what happens when you delete your fender flares!
Two Broncos with broke tie rods, two Broncos with flare deletes.
Take notes, folks.
618TRVLWILD
Ashley
Southern Illinois
Take notes, folks.
Curious for my own education..what does having the fenders deleted have to do with broken tie rods? I ask bc I got deletes at my house.
one800higgins
VW GTI
They were joking.
noliveaxle
john
Riverside, Calif
2015 jku rubicon
I believe when people run 37’s on their Broncos, they need the fender delete to clear properly. So what he is saying, 37’s are causing the problems without saying it.
618TRVLWILD
Ashley
Southern Illinois
I def realized that now. Little slow sometimes. Bronco brain not always up to par🤠🤣😂 Also I won’t ever be running a 37 or the deletes honestly.
HoosierDaddy
__ Eric
NW. Indiana
Has this been an issue on other makes / models?
Truly curious, not arguing.
Your statement is logical, but on the other hand, the 190 is rated as stronger than the old school Dana 44's.
So really, have there been other vehicles that ran an iron case center and aluminum case center at the same time?
In either case, this will make for an outstanding case study since there will be so many of each version set up nearly identically.
How many more times do you think I can squaeeze the word "case" in there? LOL
