Fordified1
Bob
Mid South Texas
This would be awesome news…I rather go 35 spline fabbed 9” over the spicer 60.
This is the response I got from Currie when I asked about a Bronco 9” back in July. Not quite sure of the response, Seems like there are more locker options for a 9” than just an ARB. What about a true trac or Detroit ratcheting locker? I have even run a spool on the street before. I have a 35 spline spool on the shelf.
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... IMG_2444
Mdsuits
05 f350, 68 bronco 89 samurai
I’ve run spools on the street myself. Not a huge deal but I would definitely prefer the selectable locker…..why can’t the factory locker wire be used to trigger the solenoid on the compressor and lock and unlock the lockers? I have 35 spline arbs on my 68 bronco and I’m happy with them.
Arokcrwlr
Kraig
US - Alabama
2014 F150, 2014 Focus, 1973 Bronco
I run Detroits in my 73. Tough and reliable - just need to learn not to goose it in a turn... Not sure about Currie's response re: available lockers for the 9". 🤷‍♂️
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
when I chatted with Loren Healy, He said they built a Ranger with a 9/10" 3rd member in the front...had to cut off and re-weld most of the suspension attachment points lower to make clearance for the bigger sized casting...for the front the 9" third member definitely would require serious modifications.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
That is interesting since so much space is wasted with the clam shell cast iron design that a fabricated housing should fit.
I would anticipate the bigger issue being that rear lower control crossmember hitting the pinion and being in the way.
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
Sooooo it fits!!!
After much customization to the cast center HP60, AND minor trim to crossmember...I have got the SUPER 10" dana spicer (ECGS) HP60 to fit in the place of the original FDU. !!!
THIS IS A GAME CHANGER!!!
I spent most of the afternoon hacking and measuring and trimming the cast section down to as minimal as possible. Sooo pumped to get this upgrade underway.
Obviously it's far from done, It'll still need ring and pinion, E-locker, and new custom 35 spline inner stub axle and intermediate axle. So its probably 2 months away from being finished.
here b4 and after pics.
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250221_161948
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250221_161939
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250221_161933
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250221_162113
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250221_162238
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250221_104230
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250221_162243
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250221_162247
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250221_110516
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250221_162101
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250221_104239
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250221_162309
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250221_164758
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250221_164849
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250221_164818
orion
Jeremy
17' F-250, 17' Explorer
Sooooo it fits!!!
Valhalla
Valhalla
Chattanooga Tn
Will it need some kind of front support? It looks awesome! If you need to donate that ultimate to someone, I could be that someone!!😁
Also, next time you have some time snap some pictures of how you currently sit... I just like to look at it!!
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
I will need new mounts for sure
mpeugeot
Sooooo it fits!!!
I can't see any difference, they're the same, right?
I seriously don't know how you made it fit, but congratulations!
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
Update....Suspension finished...16"+ wheel travel achieved with BRAPTOR arms...and ZERO heims or uniballs. ALL OEM ball joints! 73" track width (1" narrower than Braptor. )
Well , nearly a year of collecting parts, having custom parts made, overcoming numerous setbacks and the Suspension experiments are finally finished.
Many thanks to @87-Z28 , @TeocaliMG , @SierraBronco and @GreyZ for the technical details and knowledge.
To re-cap heres what the final setup uses on the front..
Braptor LCAs
Braptor UCAs
Custom FMI fabricated knuckle/upright
Braptor brake rotors and calipers
RC tie rod with Custom 4340 extensions
Custom chromoly UCA mounts
Lowered and narrowed LCA mounts
Custom Strut towers
2 ton unit bearings oem 6 lug with ABS tone ring.
35 spline 300m stub axles
RCV 60 outer 300m CV joints
935 inner 300m CVs
ORI gen 3 integrated reservoir struts 10" stroke
Braptor Sway bar
Ride height is set at 3" above SAS.
Compression travel increased by 1"
Extension travel increased by 5"
Overall, I am 100% happy with the results and the $ and extensive work was all worth it. The ride is nothing short of AMAZING. ! ORI struts are in a class of there own, totally adjustable in every aspect; spring rate, ride height, compression damping, and extension damping are ALL 100% owner adjustable and tuneable!
No Metal Springs! NO TIRE RUBBING!!! NO WHEEL SPACERS. NO BODY LIFT.
Heres a few pics during and after.
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250805_200334
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250712_163945
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250622_155755
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 88382227-527f-4c41-b6e6-04737434fc4d
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250726_004815
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250719_133423
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250807_180448
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 20250807_180641
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 12f70fc2-8dd8-4b8f-a7ce-83f0d12d92f3
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... 0e461fa7-1b4d-46d3-aaa4-5cd7a35152c7
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... b718cfba-8fbe-465d-911e-9830bb4146ea
Ford Bronco Braptorizing 2 door Bronco... First Edition Warthog... d25df2b1-af2e-47ef-a83e-2186effc4c91
