Brake Maintenance Mode?
Lil Red Broncette
Explorer
I've tried procedures I seen in YouTube videos, procedure found using google and the procedure I found on this form, none have any effect to get it into Maintenance mode.
Did Ford disable this function in an update somewhere along the way? Did they make it smarter so maybe it is not needed anymore to change the rear pads.
This is the first time either of my 2022 Broncos has needed brake pads and I've been doing them on my other cars for decades. This electronic parking brake is a new animal and this is quite frustrating.
So what's the story?
Frankie945
Frank
Louisville KY
Q50
If your Bromco is a two door it won’t let you put it in brake maintenance mode you need an expensive scanner to place in that mode or take it to the dealer and let them do the rear brakes. You can trick it by disconnecting the battery before you work on it take off the electric brake motors and hand screw them back in but then you still might get a brake code where it won’t calibrate. Odds are you’ll get the code. It’s a major pain in the ass to do rear brakes on the 2 door.
CitrusBronco
Everglades
Citrus county, FL
Everglades
I’ve posted on how to do rear brakes on a 2.3 without maintenance mode. It’s very simple and no software is required. Search for 2.3 and brakes.
tbruz
Tony
NH
1997 Tahoe 2-door, 1976 Bronco Ranger
DALOLA
Retired
Ohio 🇺🇸
'24 Mach-E, '22 Maverick, Hot Rods
The PB motors are very easy to remove & rewind, so you can replace pads....it's actually quicker/easier than screwing around with maint. mode IMO...
tbruz
Tony
NH
Took about 30 seconds to put into maintenance mode and 5 minutes to take out (again due to my error and having to rewatch the video.)
Once I got the steps down it took the same 30 seconds to take it out.......
Tbruz
Lil Red Broncette
Lil Red Broncette
Explorer
That worked great, thanks. I did it slightly different in that I compressed the cylinder as I rotated Torx for the EPB. Got the messages but between cycling power off then on and applying and turning off the parking brake it cleared.
I just did the rear brakes which seems to be the norm for those to wear way earlier than the fronts.
