Bilstein 6112 Coilover Install Video
StinkBug
StinkBug
Dallas
Too Many
Howdy. How do you like the 6112s on trail? Seriously considering buying these this summer!
I've been loving them. They ride slightly softer than the standard sasquatch shocks, but handle big hits and fast stuff much better and smoother. Basically softer but with more controlled damping. They are also very stable in the rocks and flex well. I think the best thing I can say about them is that I really don't think about them when wheeling. They just do what they should.
telenerd
Laramie
Subaru
That’s good to hear. I thought the stock Sasquatch shocks were very soft and would blow through the travel very quickly on ledges and rock gardens going slow. If the new shocks are more controlled at slower speeds that is a win for me!
StinkBug
StinkBug
Dallas
Too Many
Yes, the valving is much better. I don't think I ever felt them bottom out during UBB going fast or slow.
Langwilliams
Langley
Cleveland Ohio
2023 Bronco big bend, 2014 Harley Street Glide
The way the lower front studs were hanging in the control arm I see why some guys just cut them off. I might do this since I'm removing the base struts an the have no value to reuse except for the top plates for Bilsteins.
telenerd
Laramie
Subaru
Question, did you have much troubles getting the alignment done after lifting your Bronco with the 6112? Not sure if I would need new UCAs like an Icon or notice much difference in articulation if I am only doing Circlip 4 in the front and 2 in the back that doesn’t lift the bronco up much. Installing the Zone off-road cam lock bolts probably be a good idea during alignment.
https://www.suspensionlifts.com/sho...road-cam-lockout-plates-for-2021-ford-bronco/
Thanks
87-Z28
Andy
BMW
Thanks
OEM UCA works fine for alignment on the bilstein 6112s. Good articulation since springs are not to stiff and dampers are tuned reasonably well.
telenerd
Laramie
Subaru
Well I bit the bullet and ordered some 6112s for my Badlands 2 door Sasquatch. Will post back my results in May. My vehicle configuration is Rock Hard 4x4 Steel Belly Pan skids, Rock Hard 4x4 sliders, and stock bumpers. I did a rear seat delete, everything else is stock for people comparing weight to circlip settings. Id imagine the skids are around 200lbs, Sliders probably 50lbs or more.
Plan on doing circlip 4 in the front and 2 in the back. Hopefully that works out! If anyone disagrees with the circlip settings let me know!
the poacher
john
Whistler
2010 ford ranger
Hey SB,
Thanks for posting this vid, it is very informative and shows just how easy it is to do, if you take your time and ensure you have all the right tools.
A question for you, re. your beadlock rings, did you paint those yourself, or are they purchased?
userdude
Jared
Denton, TX
2023 2dr Badsquatch
StinkBug
StinkBug
Dallas
Too Many
telenerd
Laramie
Subaru
Hey one last question. @StinkBug Have you noticed your bronco lose a little bit of lift since the install or still pretty level still?
Thanks!
StinkBug
StinkBug
Dallas
Too Many
It hasn't been that long yet, but it's still the same height. If it settles more I can always move the clips up, but I doubt that'll be necessary.
telenerd
Laramie
Subaru
Hey @StinkBug I hate to be a pest. But I get my shocks installed on Friday. Can you do me a favor and measure from the center of the hub to the fender front and rear. Then also measure from the ground to the fender and post the measurements.
It would be greatly appreciated. Just seeing how much lift I will get and compare it to other posts that used different circlip settings.
Thanks a bunch!
StinkBug
StinkBug
Dallas
Too Many
Thanks a bunch!
I'd be happy to, but likely won't see my Bronco until next week.
